Chat Area => General Car Chat => Topic started by: Sir Tigger KC on 16 May 2015, 21:40:36
Title: Sealey 3 tonne Trolley Jack
Post by: Sir Tigger KC on 16 May 2015, 21:40:36
I need a new jack and this Sealey seems a good buy. Anyone got one and are they any good?  ::)  TIA!  :y
http://www.ebay.co.uk/itm/Sealey-1153CX-Long-Chassis-Heavy-Duty-3-Tonne-Yankee-Car-Van-Trolley-Jack-/121649349295?pt=LH_DefaultDomain_3&hash=item1c52ddc2af
Title: Re: Sealey 3 tonne Trolley Jack
Post by: Andy B on 16 May 2015, 21:44:14
If it's anything like the one Daz brought along to Newent the other year, the lowering valve is very much ON or OFF ..... very difficult to lower the car gently
Post by: chrisgixer on 16 May 2015, 22:04:05
Is Tigger asking us if that turd can be polished?
It might be ok for the first dozen uses. But would need perfectly level and smooth ground to avoid folding up sideways eventually. So you'll likely need another next year, in which case buy a decent one in the first place.
[stuck record mode on] Buy cheap, buy twice..... [click] Buy cheap, buy twice..... [click]Buy cheap, buy twice..... [click]Buy cheap, buy twice..... [click]Buy cheap, buy twice..... [click]Buy cheap, buy twice..... [click] [repeat to fade...........] (sigh....)
Post by: Andy B on 16 May 2015, 22:09:44
I need a new jack and ....
I can recommend the Arcan jack I bought from Costco a while ago ....... depends obviously on whether you're a member, know one or if Costco still have any  http://www.costco.co.uk/view/product/uk_catalog/cos_8,cos_8.5,cos_8.5.10/900930
Post by: chrisgixer on 16 May 2015, 22:11:49
Attention OOF. Attention OOF.
CHRISGIXER AGREES WITH ANDY B  >:(
;D
Post by: tidla on 16 May 2015, 22:46:36
In local stock 3 weeks ago, and yes a good lightweight jack.
Post by: Vamps on 16 May 2015, 23:03:58
;D
 ??? :o :o........................ ;)
Post by: 05omegav6 on 16 May 2015, 23:58:10
Clucking Bell... And it's not even Friday :o
Post by: Sir Tigger KC on 17 May 2015, 01:16:28
I take it you don't rate Sealey products then Chris?  ::)
Post by: TheBoy on 17 May 2015, 07:32:11
They vary almost on a yearly basis.  But always good quality.  My Arcan XL3000 actually survived the "incident" a couple of years back (although the handle didn't), not that I'd ever use/trust it again.
The lightweight one I bought to replace it is also excellent, and doesn't break my gonads when lifting ;D
Post by: TheBoy on 17 May 2015, 07:37:48
Sealey import and badge the same Chinese stuff as many other brands. Clarke are another who import and badge exactly the same stuff.
In the case of jacks, I've had both a Clarke (exact one also available as Sealey) and a couple of Arcan ones, and the Clarke one was a not a patch on the Arcan ones, yet similarish price.
Post by: omegod on 17 May 2015, 08:17:29
I have the Arcan 2 tonne one, I'd hardly describe it as lightweight at 25 kilos but it's a hell of a jack ! Think is was £80 ish in jan
Post by: chrisgixer on 17 May 2015, 08:47:24
Sorry I thought we where talking about sealey jacks...? From first hand experience of mine and other members at various meets actually using they're jacks....They're shite Tigger!
Plus yours is a a poxy narrow bodied one. Slightest uneven ground and those gay little wheels dig in and the whole body twists. It will get permanently bent.
Plus, with those, you've got to fish about unplugging the handle to let the thing down.
If you want a bullit proof garage Jack get the arcan three ton. Wide low body. Wide big wheels. Smooth lowering action. Good reliable cog mechanism. Impossible to bend. Takes omegas with ease.
If you want a good portable Jack. Get the 1.5 tone TB has. Exact same design but in alloy. With a single roller at the front iirc. ...?
Arcan! Not sealey ::)
You think all sealey products are good?
Post by: chrisgixer on 17 May 2015, 09:00:23
Should add my sealey one (exact same body as TB's and Daz's at Newent) branded fast lift and painted black, is hopeless. Immediately displayed issues with lifting a full stroke of the handle, so is actually not fast lift at all. New seals and oil after a year, no better. Hair trigger dropping the car. The body is man enough though so twice the size of your one.
Daz's sealey? ;D hair trigger drop. Cogs in the release mechanism failed almost every time. Eventually Jimbobs car got stuck and we couldn't get it down without going under the car to fiddle with that same hair trigger mechanism.
They're shit Tigger. Plus, that one, the body isn't man enough.
Post by: Sir Tigger KC on 17 May 2015, 10:20:38
Thanks for the consumer advice chaps, I'll stay away from this one then.  ::)
Post by: Webby the Bear on 17 May 2015, 11:12:58
This is the one you want ST.....
http://www.tool-net.co.uk/p-346066/clarke-ctj3000g.html?gclid=Cj0KEQjw-OCqBRDXmIWvveLE3_cBEiQAZWfImRDpwzM9vnARFL99kZwigBIdEDpVwXyWmtvoop5rEeEaAsmy8P8HAQ
You'll be surprised at the size of it when it comes!  :o
Really great for easy jacking up. But just got to practise lowering it as it suffers a little bit like AndyB says....lowering valve either on or off lol
However, having used it a lot I've got the nack to it now and I can lower slowly  :y
Post by: Nick W on 17 May 2015, 11:26:53
http://www.tool-net.co.uk/p-346066/clarke-ctj3000g.html?gclid=Cj0KEQjw-OCqBRDXmIWvveLE3_cBEiQAZWfImRDpwzM9vnARFL99kZwigBIdEDpVwXyWmtvoop5rEeEaAsmy8P8HAQ (http://www.tool-net.co.uk/p-346066/clarke-ctj3000g.html?gclid=Cj0KEQjw-OCqBRDXmIWvveLE3_cBEiQAZWfImRDpwzM9vnARFL99kZwigBIdEDpVwXyWmtvoop5rEeEaAsmy8P8HAQ)
That's what I have; a 3tonne jack needs to be lot more robust than the first one mentioned. It's bloody heavy, which is a good thing until you have to carry it indoors!
Post by: Andy B on 17 May 2015, 11:49:20
It was the best description I could come up with
Post by: Webby the Bear on 17 May 2015, 12:07:44
I wasn't ''lol''ing at your description andy.....only the fact that youre right...its either on or off!!! sills nearly touched the floor first time I let it down  ;D
Post by: Andy B on 17 May 2015, 12:40:29
but it was a naff description .......  ;D ;D
Post by: SMD on 17 May 2015, 12:43:30
I have the same jack as webster and mine too has the on and off lowering valve.
Post by: X30XE on 17 May 2015, 12:44:35
http://www.justoffbase.co.uk/Trolley-Jack-Yankee-3ton-Standard-Chassis-Sealey-3000CXD
Slightly cheaper and perfectly adequate.  Needs a rubber pad or ice hockey puck off the bay to compliment it.  :y :y
Post by: chrisgixer on 17 May 2015, 13:46:05
Yep, exactly the same as the oppsin appalling one Daz had. The ome I have in black. The one TB has. Utter rubbish I'm afraid.
Yours might be ok, but give it time. I suppose they might the odd one that is passable on a production run. ;D
Post by: driver115 on 17 May 2015, 19:32:51
got the sealey jack about a year ago /similar /same price - functional does the job, but unsure of long term reliability for the low price paid
Post by: TheBoy on 18 May 2015, 17:33:08
The one TB has.
HAD, dear fellow, had. It is no more :D
I wouldn't go that far. Its just there is so much better available for around the same price.
Post by: chrisgixer on 19 May 2015, 13:56:55
Three I've encountered, all shite. I guess there must be a good one somewhere ?
Certainly not something I'd ever recommend to anyone else, given said experiences. :)
Post by: Diamond Black Geezer on 19 May 2015, 14:36:32
What about the Halfords ones? No idea about other stuff, but very pleased with the tools, or is this another bit of badge engineering?
Post by: Sir Tigger KC on 19 May 2015, 17:47:31
I'm going to hold on for a bit as there's a really good auction near here where all sorts of workshop equipment turns up.   :y
So I'll see what I can find there.  ;)
Post by: TheBoy on 19 May 2015, 18:51:11
AFAIK, Halfords only sell toy ones, often RAC branded?
Post by: The Sheriff on 19 May 2015, 18:52:12
A jack is something I use if I have a puncture. Don't think I've had my scissor jack out for years.
Post by: X30XE on 19 May 2015, 19:44:18
 ??? Not got a problem with it currently. Time will tell I guess. Not exactly the most complicated device in the world so should be serviceable.
Post by: serek on 19 May 2015, 22:22:44
have one of them, for about year now
 in use every day on cars and vans ideal on lowered cars
http://www.ebay.co.uk/itm/Expert-2-tonne-Low-Profile-Trolley-Jack-with-Quick-Lift-Facility-31481-Draper-/161675916628?pt=LH_DefaultDomain_3&hash=item25a4a2b554
and 5 of them , and must say they worth every penny
http://www.ebay.co.uk/itm/Sealey-Tools-3003CXQ-3-Ton-3T-Trolley-Jack-Rocket-Quick-Lift-Car-Van-New-Boxed-/200370770524?pt=LH_DefaultDomain_3&hash=item2ea707525c
Post by: chrisgixer on 19 May 2015, 22:26:07
Hahaay there's my black one again. ;D
