Omega Help Area => Omega Electrical and Audio Help => Topic started by: Mr.OmegaMan on 25 May 2015, 20:46:42
Title: NCDC 2013 CDC which board do i transfer over
Post by: Mr.OmegaMan on 25 May 2015, 20:46:42
Bought a spare NCDC 2013 recently and have stripped it down and i recall something about needing to transfer the old board over to the replacement not have the (CDC Safe mode message) not sure which one though, Think it was one of the upright ones possibly the one the plug slots into?
Title: Re: NCDC 2013 CDC which board do i transfer over
Post by: Mr.OmegaMan on 25 May 2015, 21:32:15
This appears to have answered my own question...
http://www.omegaowners.com/forum/index.php?topic=88175.msg1134566#msg1134566
The only part of the CDC that is coded is the vertical board - If swapping over the CDC bottom half, make sure to keep the original vertical board with the right head unit
Post by: Mr.OmegaMan on 26 May 2015, 13:09:39
Can anyone confirm this before I butcher my own unit
Thanks
Post by: TheBoy on 26 May 2015, 15:36:03
correct, assuming you want to use just the CDC3 section from the donor unit?
Post by: Mr.OmegaMan on 26 May 2015, 15:50:42
Thanks for that  :y
Yes my CDC isn't reading any discs, Have tried 2 other cartrages with the same outcome. Rather than messing about with the laser I'm going to replace the whole CDC section on my NCDC 2013 unit but transfer the upright board an hope for the best.
I believe it's the Sat-Nav disc slot laser is the harder one to fix, Mine still sort of works once the car warms up it works 85% of the time. So will leave that alone for now.
Post by: TheBoy on 26 May 2015, 15:56:50
Yes, that'll be fine, just swap over vertical board (remove spring that side, 1 torx bolt, lift out whilst forcing CDC mech over a bit - fiddly, and with a knack, but takes me seconds).
Next satnav laser I have to do, I'm going to see if I can use a special, unique tool, often called a tunnie ;D
Post by: Mr.OmegaMan on 26 May 2015, 19:25:24
All done, For the first time in 2 years it's working again  :)
Was rather straight forward took 15 minutes all in, However I did lose one of those tiny screws you put in the radio once back on the car... Can't be far though.
Post by: Lazydocker on 31 May 2015, 18:52:55
You're calling Tunnie a tool? :o :o ::) :D
