Omega Help Area => Omega Electrical and Audio Help => Topic started by: pauls on 27 May 2015, 20:03:15
Title: rear cigarette/power plug.
Post by: pauls on 27 May 2015, 20:03:15
How long does this stay on after key removed from ignition.
Title: Re: rear cigarette/power plug.
Post by: BazaJT on 27 May 2015, 21:22:27
Mine don't work unless key turned to first position at least,so always assumed they'd shut down as soon as key turned off.didn't give it a thought that there might be some kind of "delay" built in.Could be wrong of course!
Post by: VXL V6 on 27 May 2015, 21:29:38
Same length of time as the steering wheel radio controls stay illuminated if that helps. About 30 secs on both on mine at a guess.
Post by: pauls on 27 May 2015, 21:34:03
Thats great thanks. I have my sat nav plugged into it permanently and had a thought is it on all the time. If so will slowly drain battery.
Post by: Terbs on 27 May 2015, 21:34:26
Does it work on the same circuit as the interior light, that goes off when you lock the car. If so, would have thought the circuit would be dead once the lock activates. Or as you say...with a delay if the car is not locked :)
Post by: TheBoy on 27 May 2015, 21:43:32
I thought the consumer relay was 10 mins...  ...but don't quote me!
Post by: SIR Philbutt on 27 May 2015, 22:27:33
It is - well about 5-10 mins - never timed it, and i'm not going to  :P
Post by: VXL V6 on 27 May 2015, 22:30:31
I think it largely depends on which model multi-timer module was fitted as it appears they vary by the different answers on here!  ;D
Post by: Kevin Wood on 27 May 2015, 23:31:15
There's probably a fairly wide tolerance on them too. It's not a precision instrument. ;)
Post by: zirk on 28 May 2015, 10:46:36
Only stays on, on Elites and some CDX's in my experience.
Post by: Nick W on 28 May 2015, 13:59:56
That's true for the whole car. Like a well padded hammer!
Post by: biggriffin on 29 May 2015, 19:05:27
I'll bid 15 minutes.
Post by: pauls on 29 May 2015, 20:20:02
I unplugged it after 5 minutes, got bored watching and waiting for the little green light to go out.
Post by: Andy A on 30 May 2015, 10:08:10
Same this way.  :y
Post by: omega2018 on 04 June 2015, 01:08:43
if you want a permanent supply lift the rear drivers side seat there's permanent 12v thereabouts.  think it may be for the heated seats, upstream of the rear heated seat timer.
