Omega Help Area => Omega General Help => Topic started by: mick-1975 on 30 May 2015, 17:05:03
Title: head gasket all done . but ??
Post by: mick-1975 on 30 May 2015, 17:05:03
Hi all I've just put the head back on my omega and it started with a bit of a struggle as the battery nearly flat.
 Anyway while running seemed a bit lumpy and the spanner light came on. Plugged code reader in and came up maf sensor . Once I removed it and a good luck the little wires inside are missing would this cause it to idle wroughly.?
 Also the heater blower not work now but did when first put ignition on . Maybe the battery us that flat now as not even the central locking will work. I'll put it on charge and see in morning .
 Mick
Title: Re: head gasket all done . but ??
Post by: mick-1975 on 30 May 2015, 17:06:14
At least it started first time .
Post by: Marks DTM Calib on 01 June 2015, 16:01:05
Modern MAFs are hot film not hot wire and hence there are no wires.
I am not one who generally goes for coincidences so check the head gasket work to make sure everything is back properly as remember, MAF low code can also be a an air leak.
