Omega Help Area => Omega General Help => Topic started by: tunnie on 08 June 2015, 17:50:50
Title: Power Steering Fluid
Post by: tunnie on 08 June 2015, 17:50:50
Do you check when hot? (On 2.2)
Checked about 5 mins after a 45 min drive. Not even on the dip stick  :-\
Title: Re: Power Steering Fluid
Post by: RobG on 08 June 2015, 17:55:04
Top notch on dipstick when on hot engine, lower for cold.
Post by: TheBoy on 08 June 2015, 17:58:11
Yeah, me too ;D
I'll have to see what shite Hellfrauds sell, though worried they will only sell that Dexron that covers all specs, not just DII.
Post by: tunnie on 08 June 2015, 17:58:59
Thanks Rob. Needs a topup then, smelling very burnt too. Got a suction pump, temping to top up. Thn full lock each way few times, then suck more out and re-fill?
Thought about doing that a few times?
Post by: TheBoy on 08 June 2015, 18:00:46
Its essentially atf, it always smells iffy
Post by: tunnie on 08 June 2015, 18:00:54
Yeah, me too ;D
I got some stuff from ECP.
This stuff:
http://www.eurocarparts.com/mobile/ecp/p/car-accessories/engine-oils-and-car-fluids/auxiliary-fluids/power-steering-fluid/?549771751&0&cc5_299 (http://www.eurocarparts.com/mobile/ecp/p/car-accessories/engine-oils-and-car-fluids/auxiliary-fluids/power-steering-fluid/?549771751&0&cc5_299)
Post by: TheBoy on 08 June 2015, 18:39:09
Yeah, me too ;D
This stuff:
Looks like it may be a DexIII equiv, so I'll pass. And can't get to euroshiteparts anyway
Post by: Webby the Bear on 08 June 2015, 19:00:19
The GM stuff Hellfrauds sells is rated dex 2  :y
Post by: TheBoy on 08 June 2015, 19:04:45
But does it cover DexIII as well?  GM clearly state not to put DIII in (mostly likely due to a reaction with their own damaging seals)
Post by: RobG on 08 June 2015, 19:11:14
http://unipartautostore.com/automatic-transmission-fluid-dexron-ii-d-also-power-steering-torque-converters.html?gclid=CJGptODYgMYCFQrJtAodNlsA7g
Post by: Webby the Bear on 08 June 2015, 19:20:46
Only mentions d2.  :-\
http://www.halfords.com/motoring-travel/engine-oils-fluids/gearbox-oil/halfords-automatic-transmission-power-steering-fluid-dii-1l#tab1
Post by: TheBoy on 08 June 2015, 19:40:20
Cheers guys - needs to be somewhere I can collect, as I can't wait in for delivery, and I need it reasonably quickly.
I'll pop to Hellfrauds tomorrow.
Post by: tunnie on 08 June 2015, 20:29:37
I have an ECP about 5 min walk away, so been getting few things there. Very handy.  :)
Post by: chrisgixer on 08 June 2015, 22:04:49
Did I give you back that bottle of d2? Oh wait I know, it got burned.
Post by: Diamond Black Geezer on 09 June 2015, 11:24:02
Isn't there a drain plug on the pump (or near it) for the PAS - you undo it when you want to replace the pump, thought I'd read somewhere.
At the minute I've topped mine up (after turkey baster-ing the reservoir as empty as I could) concerned that all I've done is replace the old stuff at the top, whereas all the old stuff that was in the pump is still in the pump.
Post by: TheBoy on 09 June 2015, 21:19:06
PAS topped up with the Halfords one link above. £5 odd one trade, for 1l. But more importantly, I could pick it up today, put it in the car, job jobbed without worrying about a mail order option arriving on time.
Sorry to hijack your thread tunnie, but thanks for reminding me I desperately needed to sort TBE out :y
Post by: tunnie on 09 June 2015, 21:41:45
No probs. Topped the 3.2 & 2.2 up today. Both needed a good splash.
3.2 badly needs a service and a cambelt. Must put a weekend in the diary for Brackley  :y
Post by: TheBoy on 10 June 2015, 18:57:19
I smell lamb naga and that wanky thing with an egg that you have :P
Post by: tunnie on 10 June 2015, 19:27:29
Sounds good :y
You about this Sunday afternoon? All 3 of us will be back at the weekend. No car work this time though
Post by: TheBoy on 10 June 2015, 20:52:59
Sounds good :y
Errr, "maybe". Won't know til nearer time. Text me :y
