Omega Help Area => Omega General Help => Topic started by: stuvaux on 12 June 2015, 17:45:17
Title: Foot area heating stuck on hot
Post by: stuvaux on 12 June 2015, 17:45:17
Hi,
I was just wondering if anyone else on here has had this problem. Regardless of climate settings, the foot area is always getting hot air. I have read the guides about passenger side/drivers side not working correctly, but can't see anything about this problem. I have tried the climate reset.
Any ideas would be much appreciated  :y
Stu
Title: Re: Foot area heating stuck on hot
Post by: Andy B on 12 June 2015, 19:15:50
Stu
is it not just the same as http://www.omegaowners.com/forum/index.php?topic=122571.0 (http://www.omegaowners.com/forum/index.php?topic=122571.0) but hot instead of cold?  :-\
Post by: stuvaux on 12 June 2015, 20:06:33
Stu
The only difference is that it is both sides so I thought it must be a different cause
Post by: Andy B on 12 June 2015, 20:08:46
Stu
Sorry ..... I obviously didn't read it all properly.
When my Senator did similar, it was a duff motor for the flaps on that side
Post by: stuvaux on 12 June 2015, 20:16:49
No problem! It is a bit of a confusing one, was hoping someone might have had something similar  :-\
Post by: ronnyd on 13 June 2015, 13:04:12
Firstly are you getting cool air from the dash vents?  if not you may need to service your air-con. :-\
Post by: stuvaux on 13 June 2015, 19:24:21
Currently the air con is not working, it needs re-gassing. But the upper vents are cool with the climate set to LO, yet the foot area ones are as if the climate setting was on HI...
