Omega Help Area => Omega General Help => Topic started by: Vomariini on 14 June 2015, 17:37:48
Title: Omega b, TC and rev counter not working
Post by: Vomariini on 14 June 2015, 17:37:48
Hello, first of all sorry for my bad english. I have few problems that I havent fiqured what is wrong. :( TC and rev counter dont work and automatic gearbox dont work properly.
I have readed error codes with "My Naff Code Reader" and got these:
ABS/TC
U2105(4) Present
U2106(4) Present
Automatic gearbox
P1844 (5) Present
P1844 (8) Not present
P0730 (8) Not present
No error codes with engine.. Charging, battery and groundpoints are ok. I have changed crankshaft sensor, camshaft sensor, automatic gearbox controlmodule, dashboard (not sure what is it for english), automatic gearbox, gearbox oils..
Automatic gearbox works fine either but when u drive about 70-100km/h and accelerate hard it goes to automatic fail and not work anymore like it should.
Hope u understand what i writed..  8)
Car is Omega B 2.5V6 -00, AR25 automatic gearbox  :-\
Title: Re: Omega b, TC and rev counter not working
Post by: chrisgixer on 14 June 2015, 18:22:23
Question to others, is this a failing abs Ecu?
Not had this issue myself, so no experience.
(Bump for gent from Finland with much better English than my Finnish/Swedish :y)
Post by: TheBoy on 14 June 2015, 21:14:47
No
Post by: TheBoy on 14 June 2015, 21:22:00
The 0730 in gearbox is probably the root cause - incorrect ratio.
Suspect a hydro-mechanical fault in the box.
Post by: chrisgixer on 14 June 2015, 22:32:23
No
Ok, shut up gixer! ::) ;D
Post by: Vomariini on 15 June 2015, 20:54:46
Ok, thanks.. Just thinked could it be abs unit but obviously not.. Dont know what to do and ive asked help for opel club finland forum also but they dont know too or doesnt want to help noobie..  8)
Didnt remember to tell that only error code what appears only is that p1844 (5) present from autobox. When I first time checked and erased autobox codes there was all three different codes.
Post by: Vomariini on 08 July 2015, 15:32:24
Solved auto gearbox problems by changing manual gearbox in to my car. No more automat omega to me... :D rev counter works now sometimes about two seconds and then go to red line and stays here.. :0
