Omega Help Area => Omega General Help => Topic started by: wesagog on 23 June 2015, 23:14:36
Title: Clutch engage point
Post by: wesagog on 23 June 2015, 23:14:36
Hi,
I have Omega B 1996 with a hydraulic clutch system...
I changed the friction plate and the pressure plate but my car still start move just when the pedal near the top.
So, is the clutch pedal engage point adjustable or not? If yes, how to do that...
Thanks for help
Title: Re: Clutch engage point
Post by: 05omegav6 on 23 June 2015, 23:27:34
You can't  :y
Did you also change the release bearing? If not why not? :-\
Post by: wesagog on 24 June 2015, 00:28:30
Yes I did, even it was good
Post by: wesagog on 24 June 2015, 23:46:47
Your Help Pls.
Post by: 05omegav6 on 25 June 2015, 00:03:09
Your Help Pls.
At risk of repeating myself...
The biting point isn't adjustable.
Post by: chrisgixer on 25 June 2015, 00:06:48
That's how they are I think. Never owned a manual personally, but the ones I have driven have a very long pedal and bite nearer the end of that travel.
Not something I personally think is good about the manual, hence prefer the comparatively much more refined auto.
All of which is of no use to anyone. Sorry.
Post by: al brown on 25 June 2015, 00:13:17
Agreed, my first omega was a manual and it had a high pedal. As long as it changes gear fine and doesn't slip then you are OK. I can't say they are all like that as I only had one manual omega, but I would suspect you are fine and just need to get used to the pedal travel.
Hopefully someone with more manual omega expertise will be along soon.
Post by: 05omegav6 on 25 June 2015, 01:19:52
Second post in fact :D
Should add that the previous two post were rather more eloquent ::)
