Omega Help Area => Omega Electrical and Audio Help => Topic started by: Terbs on 07 July 2015, 16:54:18
Basically, my battery (on the 2.5) is not holding charge. I did over 100 miles yesterday, but this morning the battery is dead. Once started (battery pack) its possible to do a few miles, and if you start it within a short time it will start. Leave it for any amount of time, and it won't start.
So this morning, I swapped batteries with the 2.6, and the 2.5 started perfectly, although this battery has been stood for a month.
The 2.6 then only started with the battery pack. I took it out for a run, then left it for an hour....flat as a witch's tit.
I am assuming, although only a few months old, this battery is fubared !!!!! So...what has caused it. I have noticed that the 2.5 seems to be running hot...87 to 92 every trip, whatever speed. The fan is cutting in and out for the whole journey, like yesterday, 100+ miles. Would this knacker a battery. The hot running will need to be investigated, as I do not want it fubaring the battery I have put on it from the 2.6.
And lastly, fella's...what is the difference between the battery AH. I have looked at several places for the battery, and there seems to be a variation from 60ah to 100ah for the car. Obviously lower ah, cheaper the battery in some cases. Advice appreciated, please :y
Firstly and most importantly from your financial point of view, as the suspect battery is quite new, you must have a warranty, so get it replaced FOC!
When you had the good battery from the 2'6 in the 2.5, did you experience the same heat/fan issues, or was that only with the suspect battery?
If all was well with the good battery in place and the alternator is outputting the correct voltage (get it checked FOC at several tyre and battery places) then you need not worry about sending a new battery to an early grave.
|Battery capacity? Simple; get the highest A-h capacity that will fit in the battery try, consistent with your finances - BUT, seek reparation via your suspect battery's warranty as a first move!
Ron.
Mine is 72 A/H.
GM suggest something like 65 A/H.
If all was well with the good battery in place and the alternator is outputting the correct voltage (get it checked FOC at several tyre and battery places) then you need not worry about sending a new battery to an early grave.When you had the good battery from the 2'6 in the 2.5, did you experience the same heat/fan issues, or was that only with the suspect battery?
Ron.
Highlighted....as is normal in this family, I can't find the bill (as yet) despite having a folder for all three cars which are supposed to contain everything.
Secondly, Ron...that is something I had not thought about, the running hot being connected. I'll go out and have a run after tea and check, and will report back. :y
Well, I'll go to sea in a bucket !!!! Ron...if you follow this, what is the significance between a duff battery and running hot.
I have just done 20 miles, and the temperature ran at 87 degrees, even dropping to 85 but when I caught up to a tractor it went to 90 but soon dropped to 87 once moving.
Interested to know the answer.
Battery size I am looking at is 70AH :y
Sounds to me like it's the battery if things ran fine with the 2.6 battery in place.
It's definitely the battery! Without voltage checks you can't be sure, but I suspect a dead cell. To confirm this, fully charge it off the car and measure the terminal voltage about 10 minute intervals for an hour. If it starts at approx. 12.4 volts and drops fairly rapidly over that time towards 10 volts, it IS a dead cell and will be replaced under warranty withoput quibble.
Assuming this to be the case, during driving the alternator would have been working its electrical socks off trying to bring the battery back up to full voltage and thereby taking a lot of power from the engine in doing so, causing it to get hotter.
I hope that makes sense?
Ron.
Clarification: the voltage checks need to be made after a full charge, yes, but then with the charger disconnected - I should have made that clearer!
Ron.
Cheers for that, Ron. Makes perfect sense :y
I shall take the battery out tomorrow and give it a full charge, then do as you say.
You learn something every day. :y
Also gonna pull the house apart and find that missing bill
Happy to help; please let me know how you get on, also if you get the battery replaced. Out of interest, where did you buy it from? They usually have at least 3 years' warranty.
Ron.
I bought it through the garage my son in law was manager of. The first battery was the wrong size so was exchanged....I don't know what happened to the paperwork. If I had it, it should be here somewhere. However, due to the company about to shut the depot, they did not pay bills, so some stuff had to be paid for by the workers. I think that happened in my case and I gave the bloke cash. I thought he gave me the paperwork but I may be wrong.
I'll keep you posted on the charging events.
I have to ask the question...if the alternator was working its socks off to charge the battery, how does that cause the engine to run hot. Forgive the ignorance on this subject :-[
The alternator gives up to 120 Amps output at 14.4 volts. The product of those two quantities gives the power to the battery, i.e. 1728 Watts.
Hovever, it will be a heavier load than that due to inefficiencies and friction, so say 2,000W or more. This could mean a real-life load of approaching 3 horse power.
I confess that having made these calculations it isn't great compared to the total output of a 2.5 litre engine, so there could be another factor coming into play here, but you have already proved that this sick battery is the culprit, so I'll await input from others to give another view!
Ron.
Worth following this on both cars in case one is overcharging and knackered the battery as a result, IMO.
If both cars check out OK, the battery is clearly FUBAR.
http://www.omegaowners.com/forum/index.php?topic=90619.0 (http://www.omegaowners.com/forum/index.php?topic=90619.0)
Thanks for the link Kevin. I did a search and missed that :-[
After following the advice here, and Kevins excellent link information, I think we can safely say the battery is totally knackered.
Summary is this...I put the battery on the bench and checked the voltage....12.47 volts. I then connected to a charger, and it started at 4 amps, this changed to 2 amps within 15 minutes. After an hour, with charger connected and charging, I had a readout of 14.61 volts. I disconnected after a further 30 minutes, Waited an hour, and had a readout of 12.86 volts.
I then attached the battery to the car, connected and had a readout of 12.81 volts.
Getting wifey to crank the car, (which would not turn over), I got a reading under 8 volts. Switching off, the battery returned up to 12.2 volts.
The recipient car was the 2.6 which has no electrical problems.
In the meantime, the battery from the 2.6, which was used to test the charging system on the 2.5, is holding a 12.89 charge after resting overnight, after my 20 mile test run. The car started first time with a high speed turnover. All the idle and 2000rpm and charge readings are within the expected scales. I think this negates the 2.5 systems as causing any battery problems.
Sorry this is a bit long winded but shows how our maintenance guides can be of extreme help :y
Thanks to all for contributions on this thread ;)
Yep, knackered battery. :y
Yup. If you didn't know, a battery that is '12v' that is reading eg: 9v sounds like it's ok, afterall, if you got 9/12 in a test, you'd be pretty happy with that score, 75%.
Glad you're sorted - have you a source of a good new battery?
Actually, my only local sources are Allparts, ECP, and tyre/battery places. However, swmbo is demonstrating that we are short on readies this month, so I have decided to pull the 2.6 (which is wearing the knackered battery) off the road, and service it, and other TLC. This is the one beauty of being a multiple Omega owner. Still have two on the road for use. Can't find a bill for the battery anywhere to be able to claim :'(
However, one problem sorted and another pops up......one screw holding the air filter cover on is fubared, and is refusing to come out. Lord knows what they are made of, but I can't drill the head off, but that's another story :'(
Does your departed battery have a date/date code on it? If it's as recent a purchase as you said and they know you at the vendors, maybe they will replace it on trust without a bill, because faulty products like that are returned to the manufacturer for credit usually and therefoe no loss to the vendor.
Ron.
Can recommend genuine Vx battery - go for the one-up from recommended -so A 70a/h - because it's actually cheaper than the 65a/h :y
Worked out at literally a couple of pounds more than a varta/exide from ebay. (which I'm not saying wouldn't be as good/better, but after much deliberation I decided to go genuine Vx, I didn't want in 1 years time to have a duff battery, only to find the ebay seller has long since closed down, or something similar)
given how common the airboxes are, in your case I'd be tempted to just rip the lid off, and replace the unit. It's the sort of thing many an OOF breaker would normally chuck in the bin, TBH, so should be very cheap :)
Sorry late reply DBG...just seen this post.
So just to close the thread, I tried to drill out the screw....no go. However, I managed to hacksaw across the top, then used a chisel, wd40 and a lot of grunting, and the screw surrendered :y
Thanks to all who contributed. :y
