Omega Help Area => Omega General Help => Topic started by: V8S on 09 July 2015, 12:16:57
Title: 2.2 dti Inlet manifold removal and boost sensor replacement
Post by: V8S on 09 July 2015, 12:16:57
My engine has been reliably limp-moding for a couple of months now, generally when I come to a halt. It usually clears when I've gained some speed again, but sometimes it just stays on.
I'm getting really tired of it.
A local garage checked the codes and came up with an EGR problem. They cleaned it up nice, but the problem continued so I had the EGR replaced. The problem continued.
So it seems the next thing is to take off the inlet manifold and clean it up (car has done over 200,000 miles now), and change the boost sensor. This I have gleaned from ENDLESS googling trying to find any answers, and there is not a guide anywhere on how to take off a DTI inlet manifold.
Money is tight, so I'm hoping someone here can talk me through the steps to take the manifold off so I can dunk it in some stuff to clean it up.
PLEASE HELP, as I'm sick of reading forum posts that don't give any info.  :'(
Thanks.
Title: Re: 2.2 dti Inlet manifold removal and boost sensor replacement
Post by: VXL V6 on 09 July 2015, 15:30:40
You'll need the gasket ready to replace when you take the inlet manifold off, there's nothing much to it really, unplug the boost sensor, unplug the vacuum hose off the EGR valve (or undo the two bolts and take the EGR itself off), take the inlet hose off and unbolt all the manifold bolts around the edge.
Oh and I have to ask, do you own a V8S SD1?
Post by: V8S on 09 July 2015, 16:26:49
Hi,
I'm not very practical, so 'nothing much' seems like a huge Everest-sized problem.
I'm hoping someone has a few labelled pictures they can post up to help me locate where the parts you mention are.
No, my V8S is a TVR I'm afraid. It's the V8 version of the S Series from the late 80s/ early 90s, before the Chimaera and Griffth turned up.
I do love the SD1s though. I sort of know someone who runs a rally one of those.
Thanks!
Post by: VXL V6 on 12 July 2015, 10:18:41
I'm pretty sure the Vectra C forum has a step by step guide, alas I no longer have either of our DTi's so cannot photograph the relevant parts.  :(
Post by: Webby the Bear on 12 July 2015, 11:43:11
When you remove stuf you can either label it or you can lay bolts, brackets etc down on the ground in order as they're were on the engine. I still use that trick now as I'm a right forgetful bar steward  ;D
Post by: JamesV6CDX on 12 July 2015, 15:02:32
Ok so firstly I can't offer a "mobile mechanics" service on the 2.2DTi... .aside of a few bits I've done on my own, I don't know them well enough to be comfortable in charging someone to work on them (My forte is the V6)
With that said, I'm not a stranger to spanner wielding... so availability depending, if you wanted to get together one sunny day and have a crack, I'd be up for that.
Post by: 4x4 on 12 July 2015, 15:34:32
I know where there are 2 guides on cleaning the dti inlet manifold,but as its frontera related i wont bother posting links as the frontera is a shit truck to have according to certain people on here,but if the op wants to pm me i will send him the links. :y
Post by: V8S on 15 July 2015, 00:29:38
Yes please. That would be much appreciated if it's the same engine.
Post by: VXL V6 on 15 July 2015, 21:29:29
http://myweb.tiscali.co.uk/mozzer/howtoinjectorseals.pdf
It's covered in this guide. There are others out there.  :y
Post by: Omegatoy on 17 July 2015, 20:59:00
ok easiest way to sort this is to add 2 stroke oil to the fuel, this is a known way of ,
A,keeping the injectors and fuel pump lubricated as this shit low sulphure fuel doesnt do it properly,
B,better mpg and a lot smoother engine,
 ratio is half a litre to hundred litres of diesel
I run this on both our diesels believe me it works!
Post by: Jimbob on 17 July 2015, 21:15:55
Yes,
I do this on my zafira too, makes a world of difference, I add about 250 ml to a tankful.
Post by: VXL V6 on 17 July 2015, 21:27:59
Yeh, I used to do it on ours, about 350 ml (roughly a can of pop!  ;D) per tankful.
Post by: Omegatoy on 18 July 2015, 12:23:09
lol yep it very much improves things, but the b onus is how clean the egr and turbo vanes stay,although it takes a couple if doses to clean the system out after that its great!
Post by: V8S on 05 August 2015, 11:28:11
So, if I've got a coked-up inlet manifold (and egr and boost sensor), by putting a few doses of 2 stroke oil through the system (I assume added to the diesel in the fuel tank), it'll clean it up like it would if I took the inlet off and cleaned manually?
If true, that would be great.
Post by: TheBoy on 05 August 2015, 11:46:13
Does that also apply to 2.0DTi in the battlebus shitbox?
Post by: VXL V6 on 05 August 2015, 11:52:26
Yep  :y
Post by: V8S on 05 August 2015, 14:15:14
Yep  :y
Who are you replying to?
Me about using the 2 stroke oil, or The Boy about his 2 litre?
Cheers!
Post by: V8S on 05 August 2015, 15:02:23
This page suggests it's not recommended.
http://www.fuelexpert.co.za/2-stroke-oil-in-diesel-technical-study.php
Post by: VXL V6 on 05 August 2015, 17:56:57
Yep  :y
Cheers!
The Boy! Sorry was a rushed reply on the phone.
Post by: Omegatoy on 05 August 2015, 21:01:21
lol in south africa, they add 2 stroke all the time, now believe it or not, its not uncommon for dti engines to do 5 to 600 th0usand miles, usng the 2so, if it isnt used the common rail diesels die in under 150k, now if the op adds 2so to his ailing dti, it will clean the egr etc but it takes around a thousand miles to start being effective if its really badly coked up, you wouldbe better off taking it apart cleaning it then using 2so every tankful,
the problem with low sulphur diesel is lack of lubrication, this is why shitroen renault peugot HDI pumps die,using 2so in them lubricates the hdi pump and they do really good mileage,you need to use mineral FC STANDARD 2SO FOR PREFERENCE, AS ITS CHEAPER AND LOW ASH, HOWEVER YOU CAN USE SEMI OR FULLY SYNTH its purely a cost issue,wilikinsons sell it very cheaply!
 V8S do you really think the fuel companys would tell you to add 2so to thier products? its all made to a certain lubricity standard but its marginal,and older diesels do not like it,they want everyone to buy new diesels, which are designed for usld but all thier sensors etc kepp going wrong so its a waste of time with dpf etc, on that note, if you have a dpf on your diese using 2so will actually help keep it clean, I kid you not! it regenerates a lot less using 2so as it dont soot up so muc h cos of the cleaner burn!
