Omega Help Area => Omega General Help => Topic started by: swordfish on 16 July 2015, 10:12:15
how do i identify 3.0 cams , thanks
Near the end where the pulley sits there is ring around the shaft that have a letter then a number. EG....
A19
G7
J4
The letter is the cam, the number is apparently the machine used.
so what will i be looking for on the 3.0 cams
What He said, /\.
3.0 will be G and A
3.2 will be G and J.
I should add, the number is made up of drilled dots, not cast in the metal, ignore the cast numbers.
Like this....
(http://img.photobucket.com/albums/v376/spencelayh/3_0gcamark101.jpg)
Picture from here (http://www.vauxhallownersnetwork.co.uk/index.php?threads/x25xe-2-5-v6-cam-shaft-identification.128527/)
Yea, good shout with the pic, as there are, as you say, other letters and numbers stamped on the other end of the cam, Ive seen them start with a Gxxxx even though there not G cams. The cams are or were colour coded with a ring colour mark, but guessing the colour faded after a while, hence the stamping as per the pic.
Fairly sure there's a Colour Code Table on the forum somewhere, probably one of Marks DTM early postings.
I saw a colour code table on the linky I posted above.
EDIT (again in the linky above)
C25XE Green(A) Green(A)
X25XE Brown(F) White(E)
X30XE Blue(G) Green(A)
Here's Marks one on OOF. ;)
http://www.omegaowners.com/forum/index.php?topic=90500.0
