		Omega Help Area => Omega General Help => Topic started by: EMD on 16 July 2015, 11:45:04
				Do i need to let Locktite threadlocker go off a while before
 screwing parts together or just apply and assemble ?
 Its for the screw insert on the oil filter mod  :-\
				I put a dab on, then go ahead and fit it and torque it up  :y
 Ok thanks tunnie  :)
				I mite be wrong but the guide dont mention any torque values for the screw insert  :-\
 Just screw in
				You don't need to let it go off, apply a tiny amount and assemble.
 You must ensure that both threads are clean, dry and degreased.
				Thanks nick , all done . Nice tidy leak free job  :y
 Will be so much more easier to change now . Drained and hosed out
 the pond that was dripping on my head through the chassis rail too  ::)
				well done changes will be much easier.  and cheaper. also much less incentive for a garage to just change the oil but charge for a filter change.  and more difficult to get away with.
 they do still drip oil down your sleeve when removed i have yet to try a wix filter for a catera v6 which has a one way valve and may reduce that.
 (http://www.wixconnect.com/images/filters/51040.gif)  wix part number 51040
 Your best bet is to buy my Omega for the 'giveaway' price of only £975, Mr Emd. :y
 Which is really hard for the engine side of things given it's job in life, I find.. (easy on the shiny new adapter, of course!)
				I cleaned the engine side with some cotton buds soaked in
 de greaser till no oil was visible  :y
 I put genuine vx filter on .
 £9.75 dont seem a bad price Mr opti .
 for some reason the oe filter for the cadillac catera (same engine as 3.0V6 omega) has a one way seal on it (http://images.wrenchead.com/smartpages/partinfo_resize/DCL/PF47_Primary.jpg)
 there's a good video here of the wix equivalent being dismantled here:
 https://www.youtube.com/watch?v=ndmhAFJ0cBE (https://www.youtube.com/watch?v=ndmhAFJ0cBE)
 i don't know why the oe spec is different, maybe US mechanics might sue if they got hot oil down their sleeve.
 the seal might also minimise oil starvation on start up by reducing drain from the filter.
