Omega Help Area => Omega Electrical and Audio Help => Topic started by: DrAndyB on 18 July 2015, 13:24:03
Got these from the Pending Fault codes.
Cant seemed to find them on the list ?
Car starts a great now with clean throttle body :y
I have reset the codes and there were no other codes logged.
Not sure what they are.
From my Autel
P1781 - ECM actual torque signal - malfunction detected
P1740 - AT torque control. signal malfunction
Looks like something to do with gearbox, Pending codes tend to clear with ign off/on
I'd Wait to see if they come back then do something, cam sensor is used by AT ecu
Memory tells me the Cam sensor on a 2.2 can give bizarre false autobox codes.
Thanks for advice and hints.
Have reset all and oil now changed to propper vx 10W/40 Semi.
Old black stuff which i drained seemed very "thin" but they had put 5W 30 full synth in !!!
I am happy now she has genuine GM oil and cleaning throttle body as per OOF guide has cured idle gremlin a treat :y
Will check for codes in morning as all reset and gave he a run today. Fingers crossed.
