Omega Help Area => Omega General Help => Topic started by: Migalot on 30 July 2015, 18:31:15
Title: Screen seal
Post by: Migalot on 30 July 2015, 18:31:15
I just noticed that my windscreen outer seal is broken:
(http://i114.photobucket.com/albums/n270/v6nick/windcreen%20seal.jpg)
Two questions:
1. I've tried to find out the part number and have come up with 90460335. Can anyone confirm this is right?
2. Is it a DIY job to fit?
Thanks in advance!  :y
Title: Re: Screen seal
Post by: steve6367 on 30 July 2015, 18:49:23
If yours is the top and sides in one then yes 90460335 @ £43.50 retail
It just clips in, but you want to remove the old one very carefully as if you damage the clips attached to the screen you will have to remove the screen to fix.
Post by: Migalot on 30 July 2015, 19:18:39
Thanks, Steve, but you have me worried now!!  :y ;)
What sort of method would you suggest to remove the seal from the clips? Just fingers?
Post by: davieboy0312 on 30 July 2015, 19:30:10
I would start as far down the bottom as you can. When refitting I would use a little soapy liquid in the plastic track so help slipping it in
Post by: omega2018 on 30 July 2015, 19:35:00
i think you could repair that - scrub it clean degrease with meths let it dry and then press in some (black) outdoor acrylic sealant.  will probably outlive the windscreen, the car even.
Post by: Migalot on 30 July 2015, 19:52:08
That did cross my mind, though the rest is so faded, it would stick out like a sore thumb — well, to me anyway!!  ;D
Post by: davieboy0312 on 30 July 2015, 21:01:34
http://www.genuinepartsearch.co.uk/
90460335 - £34.94 plus postage. better looking than covering it in sealant  :y
Post by: Migalot on 30 July 2015, 22:58:31
Thanks, davieboy. That looks good to me!  :y
Post by: Migalot on 30 July 2015, 23:14:24
Still worried about breaking the clips, though.  :-\
Post by: steve6367 on 30 July 2015, 23:48:19
Nice and gentle and you will be fine - don't force anything.
Mine is off ATM so will post you a pic tomorrow so you can see what it is before you start.
Steve
Post by: Migalot on 31 July 2015, 12:36:11
Steve
Thanks, Steve. Look forward to seeing the pic!  :y
Post by: steve6367 on 01 August 2015, 09:01:04
https://www.dropbox.com/photos/shared_space/WymVeEw5pH2fMyk
Post by: Migalot on 01 August 2015, 13:55:52
Thanks, Steve, that pic helps a lot!  :y :y
Think I might give it a go!  :)
