Chat Area => General Car Chat => Topic started by: Field Marshal Dr. Opti on 06 August 2015, 12:31:32
Title: Stupid Signum question?
Post by: Field Marshal Dr. Opti on 06 August 2015, 12:31:32
How many rear fog lights should I have?
Title: Re: Stupid Signum question?
Post by: henryd on 06 August 2015, 12:33:53
Probably just the offside,may only need a bulb fitting in the left one though :y
Post by: Field Marshal Dr. Opti on 06 August 2015, 12:39:48
Correct, Mr Henry. Is this legal?
I have a working bulb in the passenger side but only five wires going to the connector. The wire for the fog light is absent. I have six wires going to the other side.
Post by: Marks DTM Calib on 06 August 2015, 12:41:29
Yes that is fully legal.....but you knew that before you posted!  :y
Post by: Field Marshal Dr. Opti on 06 August 2015, 12:43:13
No I didn't.
I'm pretty sure the Omega had a matching pair. :)
Post by: Marks DTM Calib on 06 August 2015, 12:54:59
Think about it......if it wasn't legal it wouldn't have got through an MOT or type approval...very very few cars these days have two rear fogs the same as few have two rear reversing lights
Post by: Field Marshal Dr. Opti on 06 August 2015, 13:09:16
Maybe, but things are far better as pairs. Breasts and balls being  prime examples. :)
Post by: GastronomicKleptomaniac on 06 August 2015, 13:12:51
...on separate people, usually.
Post by: Field Marshal Dr. Opti on 06 August 2015, 13:14:37
Not in Thailand. :)
Post by: henryd on 06 August 2015, 15:46:57
Not in Thailand. :)
 :o :o :o ::)
Post by: biggriffin on 06 August 2015, 17:22:35
Not in Thailand. :)
Wandering into stemo territory this thresd ;D
Post by: Field Marshal Dr. Opti on 06 August 2015, 17:37:24
My 83 year old FIL took a holiday in Thailand a couple of years ago.
He innocently wandered into a dubious part of town and was approached by a beautiful young thai girl aged about 16 or 17.
She then whispered in his ear " you want me poppa" before lifting up her skirt to reveal a large dong.
He didn't wander away from the organised tours after that. :)
Post by: 05omegav6 on 06 August 2015, 20:15:06
Vectra C is the same, but the bulb is present as the car is able to sense brake light failure and uses the fog bulbs as a back up... puts the bulb warning light on on the instrument cluster as well... :y that said the Design and Elite spec cars also have check control too ::)
As for FIL, what happens on tour, stays on tour :-X
Post by: Webby the Bear on 06 August 2015, 20:25:47
 ;D ;D ;D
Hey, if he wants to experiment I say go for it  :y
Post by: Field Marshal Dr. Opti on 06 August 2015, 21:15:05
Ah...I see why the bulb is there now. :y
Post by: biggriffin on 06 August 2015, 21:17:37
 ruved him rong time,.
Post by: Field Marshal Dr. Opti on 06 August 2015, 23:04:54
He takes his holidays in Blackpool now. ;D ;D ;D
It's safer. ;)
Post by: Rods2 on 08 August 2015, 01:42:45
Explains much about STMO holibobs and why he is missing from OOF. :o :o :o :o
Post by: Phil on 10 August 2015, 10:17:30
There is a setting that via Tech2 changes the fog light position from left to right.
You only need one and it has to be the off side one.
Its the same for the continent so rather than make a left hand and right hand light clusters they just change the settings
If the brake fails its actually the side light bulb that takes over with a higher voltage to make it look like the brake light, not the fog light that illuminates
Post by: 05omegav6 on 10 August 2015, 10:46:58
If you activate the abs you get six bulbs, all 21w all flashing. Having had four facelift Vectra Cs, I can't see the Signum being any different. Put another way, if it never illuminated, it would never have a bulb fitted ::)
Post by: Phil on 12 August 2015, 06:27:22
Please read the manual - fog light position is country specific, opposing side can be used as a spare bulb holder - fog light does not illuminate in event of brake or side light failure, cheaper to have some donkey in a factory installing all bulbs at a few pennies each rather than having piles of country specific units cluttering up half of Germany.
Having owned 2 Signums, a pre facelift and a facelift, neither had a bulb in the near side fog light, both have the tail or brake light work as dual use in event of bulb failure
Post by: biggriffin on 12 August 2015, 07:11:34
Told ya.
Post by: 05omegav6 on 12 August 2015, 09:06:05
 ;D Send me the owners manual to read then :y I only have a Vectra C one here...
Have you seen what lights up when you fire the abs? ::)
Post by: Phil on 13 August 2015, 07:11:28
You obviously have an old manual, have a look here:- http://vectra-c.swi.hu/VectraManual.pdf specifically p226
(http://img.photobucket.com/albums/v508/Stoneshed/Vectra%20C%20manual.png)
Everything is likely to light up on failure as you can via the regional settings change which side the fog light is, you can also turn on DRL's if you are that way inclined
