Chat Area => General Car Chat => Topic started by: T.m.f on 18 August 2015, 18:55:11
Title: Lpg tank fittings
Post by: T.m.f on 18 August 2015, 18:55:11
been having a problem when filling up with lpg,past couple of times its not cut off when full,its a 4 hole ext cylinder tank,whats the name of the part i need .
Thanks.
Title: Re: Lpg tank fittings
Post by: Lazydocker on 18 August 2015, 19:18:29
Same pump or different pumps?
It's the fill valve you need but it needs more diagnosis
Post by: T.m.f on 18 August 2015, 19:20:10
Different pumps it happens at.
Post by: Lazydocker on 18 August 2015, 20:00:48
I've had it before and it's fixed itself but it sounds like the float has fallen off
Post by: T.m.f on 18 August 2015, 20:07:17
Just checked tank and wasnt sitting level,must have got moved when off roading the other week,put it back level so will see how it goes for now,will need to fill it again at the weekend any way. :y
Post by: Lazydocker on 18 August 2015, 20:11:42
If it moved when off reading then it isn't mounted up to COP 11 standards :o
Post by: T.m.f on 18 August 2015, 20:21:57
Its going to be remounted after ive done a 2" body lift,just that the angle iron frame its mounted on isnt thick enough for me going off roading,so causes the tank to rotate when the angle iron hits something,it will also be having a plate fitted to protect it even more when new frame is made.
Post by: 05omegav6 on 18 August 2015, 20:45:03
A clear sign that absolutely no thought was put into the mounting location/method... :-\
Post by: Lazydocker on 18 August 2015, 20:50:44
At least he is aware and intends to sort it. As a guide, my Range Rover had twin sill tanks and I could use them as rock sliders without the tanks moving :o ::)
Post by: EMD on 18 August 2015, 21:02:44
 :D :D
Post by: 05omegav6 on 18 August 2015, 21:04:12
Fair point well made ;)
