Omega Help Area => Omega General Help => Topic started by: jamiew on 20 August 2015, 17:02:49
anyone ever have trouble with speedo or rev counter being very intermitent or random can be sitting still and put wipers on and speedo will jusmp about???? :o
Might be a grounding issue... Is the cluster seated correctly?
Also any sign of the ABS/Tc lights when it plays up?
It's probably going WTF, how many horses at that rpm? ;D
problem could be I'm not running any abs it was all removed when hydro and monaro brakes were fitted but runs a crsa c relay mated to the front abs sensor
Not sure that the relay can hndle the high/low frequency the abs sensor would generate. You may need to feed the signal through a microcontroller to interpret the feed and produce the correct signal.
Could be an interesting arduino project?
I've had this with my rev counter, randomly will jump about and then it's fine again, very strange but a new cluster is cheap enough on the bay.
