Omega Help Area => Omega General Help => Topic started by: pauls on 22 August 2015, 12:26:20
Title: trying to stall
Post by: pauls on 22 August 2015, 12:26:20
Driving from cold on the way to work if I get stuck in stop start traffic after about 5 mins of doing this the car trys to idle but the revs feel like they drop and its going to stall. This happens wether its in drive or neutral.  When traffic clears and I can drive normal for a few miles, when doing stop start driving again it will run and idle fine.
any ideas please.
Title: Re: trying to stall
Post by: zirk on 22 August 2015, 12:38:48
Any Codes?
Post by: pauls on 22 August 2015, 12:45:23
No codes..
Post by: zirk on 22 August 2015, 12:53:41
Start of a misfire?, try unplugging the Maf, does it get better or worse.
Also what's the temp gauge doing when this happens?
Post by: pauls on 22 August 2015, 13:09:17
Will try the maf .. trouble is it only happens now and again. Can I leave it unplugged for a few days. Temp is either just warming up so around 80
Post by: Andy H on 22 August 2015, 13:25:33
Initial thoughts are that either the ECU is being given duff temperature readings during warm up or that you have 'carburettor icing'
Any frost on the throttle body?
The 3.2 gets air temperature from the MAF so the MAF is one suspect. It gets coolant temperature from a different sensor to the dash so you need a code reader that can show live readings if you want to check that one.
Post by: zirk on 22 August 2015, 13:27:01
Ideally you want to unplug the maf when its doing it, leaving it unplug it will run rough and drink petrol.
I was half thinking, stop start traffic, temp going up, hence air intake temp going high and map miss reading.  :-\
Post by: TheBoy on 22 August 2015, 15:21:12
Do the throttle butterlies fully shut?
Post by: pauls on 22 August 2015, 15:36:42
Yes and both clean..
Post by: TheBoy on 22 August 2015, 19:09:05
Any airleaks in the intake?
Post by: pauls on 22 August 2015, 19:33:51
Not that I know off
Post by: pauls on 03 September 2015, 19:14:22
Change maf for a new bosch one and its still as bad as every if not worse.. Any ideas please.
Post by: EMD on 03 September 2015, 19:22:38
All plug wells dry and no sign of corrosion on the coil packs  ???
Post by: pauls on 03 September 2015, 19:38:05
Yes all clean and dry.
Post by: ffcgary1 on 03 September 2015, 19:59:49
crank sensor starting to fail.?
Post by: TheBoy on 03 September 2015, 21:16:04
Now you have a gadget...
what is MAF reading at idle?
What is desired engine speed
 What is actual engine speed
