Chat Area => General Car Chat => Topic started by: TheBoy on 22 August 2015, 14:31:13
Title: vac hoses and rubber elbows
Post by: TheBoy on 22 August 2015, 14:31:13
Specifically for Zafira, but I think they must be universal.  I've tried all the usual outlets around these parts - ECP, GSF, independents, none of them do it :(
Any ideas?
Title: Re: vac hoses and rubber elbows
Post by: Varche on 22 August 2015, 14:35:37
Omega breaker?
Post by: EMD on 22 August 2015, 14:45:26
Think i got some from wilco car parts last time  :-\
Post by: Andy H on 22 August 2015, 14:50:12
Theses?
http://www.courtenaysport.co.uk/buy-online/shop-by-category/parts/vacuum-valves/fittings/vacuum-joiner-rubber-angled/prod_929.html (http://www.courtenaysport.co.uk/buy-online/shop-by-category/parts/vacuum-valves/fittings/vacuum-joiner-rubber-angled/prod_929.html)
(http://www.courtenaysport.co.uk/images/uploads/Angled_Vac-Joiner.jpg)
Post by: Rods2 on 22 August 2015, 14:52:13
Standard rubber tubing you can buy off the shelf and will be much cheaper than those designated 'car parts'. I have never tried but I would have though the vacuum pipe would also be available. I have got a cheap digital vernier caliper that I got as an Aldi or Lidl special offer that I use for measuring internal and external diameters.
Alternatively if you need a molded bend, measure the internal diameter and look for an equivalent on somewhere like here:
http://www.ebay.co.uk/itm/90-Degree-Silicone-Elbow-Bend-Hose-Silicon-Rubber-Coolant-Radiator-Pipe-Car-/330650756290 (http://www.ebay.co.uk/itm/90-Degree-Silicone-Elbow-Bend-Hose-Silicon-Rubber-Coolant-Radiator-Pipe-Car-/330650756290)
If you do use pattern parts, let us all know as I'm sure there will be much interest from some of the regulars on here. ::) ;D
Post by: Andy H on 22 August 2015, 14:55:45
Or these
(http://www.minisport.com/media/catalog/product/cache/1/image/265x/480a488820ca6be8b35c3ea79105c0b6/1/2/12b2062.jpg)
http://www.minisport.com/12b2062-vacuum-pipe-connector-elbow.html (http://www.minisport.com/12b2062-vacuum-pipe-connector-elbow.html)
Post by: TheBoy on 22 August 2015, 15:15:38
I actually use A-series vac advance elbows for the actual elbows. Not ideal, but good enough.  I'm really struggling on the straight connectors (which is the immediate urgency) and the vac pipe itself, which is a plastic (like on Omegas), not silicone.
GM parts are:
4 (elbow) 90324140  8 07 314 HOSE, CONNECTING, 3.5 MM ID., FILTER TO VACUUM CHARGE PRESSURE CONTROL SOLENOID VALVE       1
7 (vac hose) 90018280  12 11 202 PIPE, VACUUM, 190MM, VACUUM CHARGE PRESSURE CONTROL SOLENOID VALVE TO TURBOCHARGER       1
8 (elbow) 90572322  12 12 473 HOSE, 3.5 MM ID., VACUUM PIPE       AR
11 (rubber - straight) 90166288  8 20 494 HOSE, CONNECTING, 3.0 MM ID. X 1M, VACUUM PIPE TO VACUUM PUMP       1
12 (t-piece) 9281478  8 19 763 DISTRIBUTOR, VACUUM PIPE, VACUUM CHARGE PRESSURE CONTROL SOLENOID VALVE TO VACUUM PUMP       2
Post by: Rods2 on 22 August 2015, 15:34:09
GM parts are:
3.5mm ID pipe http://www.gsfcarparts.com/186vg0010 (http://www.gsfcarparts.com/186vg0010)
3.5mm OD silicone pipe http://www.advancedfluidsolutions.co.uk/clear-translucent-silicone-tubing-244-c.asp (http://www.advancedfluidsolutions.co.uk/clear-translucent-silicone-tubing-244-c.asp)
3mm or 4mm PTFE vacuum pipe http://www.ebay.co.uk/itm/PTFE-Tubing-Metric-3-15mm-OD-Sold-by-the-Metre-Air-Tube-/231640720997?var=&hash=item35eedce665 (http://www.ebay.co.uk/itm/PTFE-Tubing-Metric-3-15mm-OD-Sold-by-the-Metre-Air-Tube-/231640720997?var=&hash=item35eedce665)
3.00 ID http://www.ukclassicparts.com/products/engine/vacuum-advance-retard-rubber-tube.asp
What are the internal diameters of the T piece?
Post by: Andy H on 22 August 2015, 16:27:52
http://www.minisport.com/12b2095-vacuum-pipe-connector.html (http://www.minisport.com/12b2095-vacuum-pipe-connector.html)
(http://www.minisport.com/media/catalog/product/cache/1/image/265x/480a488820ca6be8b35c3ea79105c0b6/1/2/12b2095.jpg)
If you are trying to connect two pipes of equal outside diameter then a short piece of rubber hose would do the job :-\
Post by: TheBoy on 22 August 2015, 18:46:20
GM parts are:
Thanks.
I've tried the silicone type and the fuel leak-off types, and they fail in a few months.  I've got a load still here, but its rubbish.
Post by: Andy H on 22 August 2015, 18:52:23
Why do you think they fail so quickly?
Is it poor quality materials? or are they subject to unusually arduous conditions?
Post by: TheBoy on 22 August 2015, 18:56:49
Not sure. Obviously, near the turbo get a bit warm, but no idea why the other area fail. Its not a massive vacuum...
Post by: Andy H on 22 August 2015, 19:03:52
The vacuum will act to hold things together, maybe there are moments of positive pressure? :-\
Post by: Rods2 on 22 August 2015, 21:35:34
You will probably find the PTFE tubing a bit better as that has a slightly higher melting point of 326.8degC compared with about 300degC for silicon tubing.
Post by: TheBoy on 23 August 2015, 17:39:25
I wonder if Omega ones would be any good.  Must be loads of people breaking Omegas.
Only one way to find out.
