Omega Help Area => Omega General Help => Topic started by: berserkerboy on 25 August 2015, 09:33:04
Started yesterday. Thought it was water getting onto the coil pack which has happened before. Fault code P0650 showing. Thoughts anyone?
P0650 Malfunction Indicator (MI) Control Circuit High Instrument
P0650 Malfunction Indicator (MI) Control Circuit Low Instrument
P0650 Malfunction Indicator (MI) Control Circuit Open Instrument
Thanks in advance
Mine is, too. I've put it down to a vac leak/duff lav reservoir, which I'm still trying to trace.
Have you checked the throttle body, may be clogged a bit, that can help with idle?
