Chat Area => General Car Chat => Topic started by: fcc-pt on 27 August 2015, 20:46:04
So half an hour ago I've gone to supermarket, about 5km from home, minutes latter when I came back to the car there it was a trail of water behind the car and a pool of water at the ground.
Opened the bonnet and while running big hose without any pressure but tank with pressure! What does this mean? If squeeze the big hose can ear the water flowing back to the expansion tank.
Big hose was hot...
Assuming that's coolant then you have a big leak. You need to find where the leak is.
Get someone to play with the heater settings whilst you watch the HBV as that's probably the most common coolant leak on the Omega.
So it's HBV for sure it must be because I was playing with AIRCON one hour or two before...
I wouldn't say it's that for sure.
If you have A/C on, the water you're seeing could be from this (that's normal).
Is it definitely coolant and are you losing coolant rapidly?
It is coolant for sure and I feel that something is blocking the circulation.
Now stopped till new HBV arrives.
Perhaps it good idea to change the thermostat also, and yes coolant has gone while I was stopped except the small amount kept in the expansion tank I could feel the big hose all empty!
If hbv is leaking,there isnt a blockage,fix hbv 1st and then refill coolant,and bleed it,then see if there is a problem,we know have 2 threads started for same problem,which may get confusing for the older members on here :y
Sorry for that, I was kind of freaking out no answers no support I can't loose that car It means a lot to me...
I'd have tested it first before ordering a new one. Coolant can leak from anywhere in the system. HBV is common but not definite.
As TMF said, fix the leak first then see where you are. in my opinion :y
You have had replies from me and several other members on both threads tho.....
Excuse me... i didn't meant to be rude or anything close.
How to diagnose HBV?
How to repair the leak?
Were should I start?
This is how I would do it......(though perhaps others have other methods)
1. top coolant tank up with water (no point wasting expensive coolant as you know you have a leak
2. start car and run up to temperature
3. watch HBV whilst a friend plays with all the heater settings (try full cold, full hot, medium heat, full fan, low fan, a/c off, a/c on etc etc)
4.) at some point you should see coolant dribbling out from hbv whilst your friend is doing this
5.) if it is leaking, look in maintenance guide for ''HBV replacement'' and follow the procedure
Start by reading the how to guides,very helpfull and covers 99% of problems omega owners have ,
And try this....
http://www.omegaowners.com/forum/index.php?topic=90574.0
Got it, thanks a lot for the guidelines.
Praying for HVB...
Where can I get a genuine one for a reasonable price?
And try this....
Reading right now :)
Praying for HVB...
Opel dealer.
Opel dealer.
Not here! Extremely pricey!
Will this fitt my Omega B Caravan MV6 3.0 from 1997?
http://www.vauxhall-car-parts.co.uk/cgi-bin/sh001234.pl?WD=90566947&PN=VAUXHALL_HEATER_VALVE_-_90566947N%2ehtml#a90566947N
So good news and bad news, I found out the problem... it wasn't not the HBV but had it replaced anyways it was old and very fragile done!
So the leakage was something bigger and difficult to repair as I have to remove the inlet manifold :( the hose that connects the back of the engine to HBV is broken near the engine clamp (I guess because water is coming of from there). How and bought the HBV at local dealer at a great price!
Case closed!
Case closed!
The heater bypass valve has been replaced, I got it at the Opel dealer by 35€ vat included.
Besides the valve I got the hose that comes from the engine to the HVB also replaced.
For now no coolant loss... Houston we got heat :)
Thank you all for your help and good advices.
I just regret not being as good as i would like so i could help others like me...
