Omega Help Area => Omega General Help => Topic started by: EMD on 01 September 2015, 22:09:30
Title: Metal on metal sound
Post by: EMD on 01 September 2015, 22:09:30
So air con works fine , nice and cold . But now when its switched on there is a metal on metal scraping sound  >:( Whats up now  :-\
Title: Re: Metal on metal sound
Post by: amba on 01 September 2015, 22:41:18
Compressor bearings ?
Not sure how to test but a long screw driver or similar metal rod on compressor ,other end to ear and see if the noise is from there.
Dont see much lese could give that problem as only the compressor pump is moving the rest is just pressure and cooling
Post by: EMD on 01 September 2015, 22:59:55
Are the bearings replaceable amba or is it a new compressor  :-\
Post by: amba on 01 September 2015, 23:10:55
Not really sure tbh. Expect bearings are available as sure I remember my AC guy saying he has done them before but by the time you replace seals etc it easier just fitting anew pump,trouble is they are best part of £200 then fitting and regas so not a cheap exercise.
My ac does sound quite rattly when its running but as long as it works and keeps car cool or dry just live with it .If real metal /metal sound then expect something will let go sooner than later so try the ear test first before condeming it but cant see what else it could be.
Worry is if the bearings are starting to break up they will be leaving small metal deposits inside the system which will further kill it.Remember when had compressor replaced before guy showed me the oil from system on his hand and had loads of small metal filings in it .
Ended up needing new compressor/and dryer unit so hurt my pocket .
Best of luck with it
Post by: EMD on 01 September 2015, 23:18:51
Ive got one i can take off the 2.5 and use if need be , ill just put a non ac belt on that one . But i will check out the noises first like you said  :y
Post by: T.m.f on 02 September 2015, 17:43:20
Remove aux belt ,turn compressor by hand,you should feel it and hear it making noises.  :y
Must be northants air,as frontera compressor needs changing aswell.
Post by: biggriffin on 02 September 2015, 18:52:03
Is noof'er air like hoof'er water Special'
Get a tin of wd with a little tube and squirt a bit into the front, might be the springs creaking.
Post by: EMD on 02 September 2015, 22:11:34
Thanks N/Hoofers , i shall try both and hope the noise goes away . Not had a chance to look yet as been drinking too much magic water and feeling sick  :(
Post by: Webby the Bear on 02 September 2015, 22:19:15
Yeah take the aux belt off and spin it by hand and move the pulley for was and backwards with your hand. Justreplace if play there
Post by: Sir Tigger KC on 02 September 2015, 22:54:30
You should watch that at your age!  :P   ;D
Post by: EMD on 03 September 2015, 12:16:22
Sprayed it all in WD and its all quiet now  :)
Post by: Sir Tigger KC on 03 September 2015, 12:29:50
It's wonder stuff!  :y  Apparently you can spray painful joints with WD as well to good effect.  :-\
Post by: STEMO on 03 September 2015, 12:41:35
And, according to Opti, it makes a good fly killer.
Post by: EMD on 03 September 2015, 13:35:19
Ive got a big tank full of Magic n'hoof water , this is what goes into the omega .. soft and pure ... i didnt drink it honest  :-X
