Chat Area => General Car Chat => Topic started by: Webby the Bear on 09 September 2015, 22:56:12
Anyone ever tried this stuff? I put a tin of it in a car today at customer;s request (with an oil change) and got to say it was noticeably quieter immediately!
have seen more than one video where this stuff puts compression back up when one cylinder was off! don't know why but thought about trying it in the omega.
Snake oil,the only one I've seen work is the lifter tonic and that's pretty good
Formulated to maintain oil pressure at high temperatures , improve performance and compression in worn engines , reduce oil consumption and exhaust smoke, quieten noisy engines, reduce friction and wear , prolong engine life and be safe with catalytic convertors and turbochargers.
If 2.2s oil consumption comtimues, might chuck a can in for a laugh. But so far, had little luck with Wynns products. :-\
Fair enough boys. thing is I suppose these yutube vids can be rigged however they want!
there'd be no harm in chucking some in to the omega, right?
Halfrauds sell a tin for £7, think with trade card should be around a fiver. :y
Im glad its not just me using shed load of oil in a 2.2
Hardly a test though......you put it in and changed the oil........the lowering of noise could be the additive (it wont be) or the fresh oil (most likely)
It's been fine until about 181k - never used a drop. Now it needs a very small top up every 750 miles or so. I'm keeping an eye on it :-\
Fair comment.
Is there any harm in trying it? i.e, stuff in, it dislodges a bit of carbon, oil strainer clogged....you know the rest..
With the exception of lifter treatment, I would always advise using a good oil and absolutely nothing else. If the engine has issues then no magic potion is going to correct them
Ive used 3 bottles of that lifter treatment and 3 oil changes but still it wont get rid of the tap tap lifter noise from the drivers side :(
That'll means its fooked then :-\
I do wonder about GM's penny pinching in later years, my 3.2 has the same problem. Dead lifter, lifter treatment no good either :(
Ive tried thrashing mine but it dont make any difference . Im saving to get it done at sereks over the winter , think that will be a totally rebuilt engine after that ::)
I did just once, get it to shut up when hot. I'd parked up, but was at engine idle for a while. Parked on a double yellow :-X
I made a get away once I saw traffic warden coming, it was an annoying day, so from idle to red-line several times ::)
Stopped again, silence. :o Did hope I fixed it, but nope back again. Defo a busted lifter :(
As henry said its knackered :( Funny how most seem to suffer
on the drivers side bank :(
Are the lifters expensive ?
Best to source known good ones from breakers.
On a visit to MasterDTM, he kindly gave me a set. Some time ago now :-[
Let it tap. As soon as you fix them something else will break.
http://www.ebay.co.uk/itm/x24-OPEL-VAUXHALL-2-5-24V-V6-C25-X25-SE-HYDRAULIC-TAPPETS-LIFTERS-SET-24-PCS-/271417082044?hash=item3f31b800bc
So £6.25 each, delivered then :D
I think they're about £15 each if bought singly. ;)
Many years ago, they were called viscosity treatments, (stp-wynns-redex) then they allowed the motorists to have synthetic oil, so you shouldn't need an oil tweetment,if you cange the oil regularly, it should stay within its viscosity spec.
mineral oils go out of spec, hence the need for improvers(tweetments)
Super- charge , mr bear needs this :)
(http://www.projektopel.de/pics/omegav6kompressor.jpg)
So, if one was to try aforementioned gloopy sh*t then it could free up a chunk of carbon and clog strainer?
Are they all the same on the V engine :-\
Edit... Looks like it
http://www.ebay.co.uk/itm/FEBI-17105-Rocker-Tappet-/291262291984?fits=Car+Make%3AVauxhall&hash=item43d095e010
No very early ones are tad different, but I think all after 1997/8 ish are the same?
