Omega Help Area => Omega General Help => Topic started by: Andy663 on 11 September 2015, 08:04:15
Title: K-Seal
Post by: Andy663 on 11 September 2015, 08:04:15
Will K-seal damage my engine or is it safe to use on a 2000 3.0 V6?
thanks,
Andy
Title: Re: K-Seal
Post by: amba on 11 September 2015, 08:55:36
Do not ever put that stuff anywhere near an engine. >:(
It will block the small pipework in the heater matrix and cause it to blow as the flow will be restricted. :(
The stuff "may" temporary cure a small leak in the main radiator or similar ,but the problems it will cause in later use are just not worth it.
Take my advise and steer well clear of any of those "Magical Snake Oil Fixes" especially if you intend keeping the car.
What are the problems you are hoping to cure with it anyway.
Title: Re: K-Seal
Post by: GastronomicKleptomaniac on 11 September 2015, 08:56:41
Don't do it, you'll end up with coppery mess all through the cooling system and it probably wont fix your problem. Why are you considering it?
(I tried it as a last resort on a car I didn't have the inclination to fix properly, then regretted it...)
Title: Re: K-Seal
Post by: Andy663 on 11 September 2015, 12:06:08
I've got water leaking from somewhere in the centre of the engine, it's collecting underneath the sump. I need to top up the reservoir every week to 10 days. Any ideas where it might be coming from?
Title: Re: K-Seal
Post by: 05omegav6 on 11 September 2015, 12:40:20
Thermostat housing, coolant bridge, oil cooler plate are three common places on top of the engine, and the HBV if it's pouring straight to the floor...
Not one of which is fixed with K seal ;)
Title: Re: K-Seal
Post by: amba on 11 September 2015, 13:47:16
Strip things down to investigate properly and then it can be repaired.
Adding a "Quick Fix" remedy will not cure it ,trust me ;)
Title: Re: K-Seal
Post by: Kevin Wood on 11 September 2015, 13:59:28
Nothing one of which is fixed with K seal ;)
Fixed. :y
Title: Re: K-Seal
Post by: Sir Tigger KC on 11 September 2015, 14:05:33
Fixed. :y
Not even Uncle STEMO's incontinence problem?  ???  :-\  ;D
Title: Re: K-Seal
Post by: biggriffin on 11 September 2015, 14:13:34
Fixed. :y
Cork for one orifice, and cable tie for tother, should stop leakage, and gaffer tape to secure,the fix. ;D
Title: Re: K-Seal
Post by: STEMO on 11 September 2015, 15:59:53
Sounds like a good look....... :-*
Title: s someone
Post by: Gaffers on 11 September 2015, 16:03:26
As someone who spent a few hours flushing the remenants of k-seal out of a coolant system wednesday morning, here is my take on it........
NEVER
USE K-SEAL
........EVER!!!!
Title: Re: K-Seal
Post by: plym ian on 11 September 2015, 17:10:43
Wot he said
I used it once and it blocked up the coolent channel from the block to the head
Title: Re: K-Seal
Post by: Steve B on 11 September 2015, 17:27:02
Remember the jeep thread i done last year and Sandicliffe  ;D ;D ;D
