Chat Area => General Car Chat => Topic started by: tunnie on 18 September 2015, 20:25:11
Title: Rear shocks top nut
Post by: tunnie on 18 September 2015, 20:25:11
The removal of rear shock top nut, what size spanner was needed for the centre flat bit.
Was it 5 or 6mm? I used an adjustable last time, but want to invest in proper size as it slipped too easily.
Cheers
Title: Re: Rear shocks top nut
Post by: 05omegav6 on 18 September 2015, 21:03:01
It varies according to manufacturer  ;)
Post by: tunnie on 18 September 2015, 21:16:57
GM's coming off....
I'll get a few then, 5 through to 8  :)
Post by: Sir Tigger KC on 18 September 2015, 21:38:57
Sounds like you need to invest in a decent set Tunnie.  ::)  One of my best ever Xmas pressies was a 5mm - 24mm spanner set!  :y
Post by: tunnie on 18 September 2015, 21:48:48
Current set goes down to 8. Also got the ratchet set, and other ratchet set with wiggly ends too.
Just not small enough  :(
Post by: Andy B on 18 September 2015, 21:58:51
Cheers
No idea of the size of spanner you need, but there are adjustable spanners & there are adjustable spanners. I've a collection of Bahco adjustables which includes a couple of these (http://www.ebay.co.uk/itm/BAHCO-8069-BLACK-ADJUSTABLE-SPANNER-WRENCH-100MM-4-INCH-/191073954274?hash=item2c7ce529e2) ...... they're not infallible, but better than your average cheapo 'mover'
Post by: tunnie on 18 September 2015, 22:02:13
Cheers. Ones I have are not brilliant, but did job just. This time want right size really, avoid rounding them off.
Post by: TheBoy on 19 September 2015, 09:50:47
I melted my 5, 5.5 and 6mm ones which I had to cover most eventualities.
Post by: Nick W on 19 September 2015, 10:35:29
It's such a small size compared to the thread that rounding them off is quite normal.
Then you switch to mole grips to get the job done.
Not having the correct size spanner just means you skip the first step.
Post by: GastronomicKleptomaniac on 19 September 2015, 11:30:32
Halfords socket sets go down that small, admittedly in 1/4" size.
Having said that I just chopped the old nut off mine, ready for replacement, as the thread and nut were both knackered.
