Omega Help Area => Omega General Help => Topic started by: laney101 on 12 October 2015, 08:41:09
Title: 2.6 v6 manual
Post by: laney101 on 12 October 2015, 08:41:09
bought a 2.6 manual 52 plate elite a few months ago. low milage sub 80k.
cracking car cant fault it does miles and miles effortlessly.
but i have a couple of things. i drove my dads 3.2 MV6 auto other day and wow such a difference more instant response, more torque, goes like stink and is on 130k and just as smooth
when i bought my car  i had the cambelt and waterpump done spark plugs full service gaskets and fitted 2x G cams on inlet as after a lot of reading they where best cams to fit.
after that it just seems flat until around 3000rpm when you actually fell it take off. below 3000rpm its quite gutless i don't know if this is cams, being a manual or  nature of car.
 but when i had a 2.5 auto was a lot better low down and my dads 3.2 is better in every respect. this 2.6 seems like something not quite right
can anyone help or advise ??? as motor is nice and don't really wanna get rid.
Title: Re: 2.6 v6 manual
Post by: 05omegav6 on 12 October 2015, 09:50:25
Check the multirams are working properly...
Post by: Andy B on 12 October 2015, 11:26:52
Was there a difference between before & after cam belt change? Was a cam kit used or just best guess without one?  :-\
Post by: laney101 on 12 October 2015, 13:36:59
Cambelt was done  in garage and they are good trust worthy..dont know if they used a locking kit. I never have on any engine and never had a problem.
But i never drove car before cam change i bought it dad drove it home and it went garage as wasnt using it for A while so got everything i wanted done on it done in one hit .
Multirams how do i check they are working correctly
Post by: Bojan on 12 October 2015, 13:56:12
Checking the multiram: rev the engine, see if the valves operate (open-close).
There are two valves: one is on the intake, between dual tubes, other is on the back of the intake plenum (above the DIS pack).
When multiram is not working properly, car is very underpowered on low-revs.
Post by: laney101 on 12 October 2015, 14:05:39
Are these the plastic valves that kind of look like actuators .. with air lines to them
One one on front between dual pipes
And one at back by dis pack
Can you see them open and close
Post by: Andy B on 12 October 2015, 14:22:07
....dont know if they used a locking kit. I never have on any engine and never had a problem.
There are too many variables when doing a V6 cam belt and it can only be a best guess without a locking kit and very easy to get it a tooth or two out.
Post by: Andy B on 12 October 2015, 14:25:46
http://www.omegaowners.com/forum/index.php?topic=90513.0
yes you can see them move ...... you do need to give it some revs though
Post by: terry paget on 12 October 2015, 14:27:04
Flat at low revs sounds like plenum dual ram not closing. May be stuck or hose off or switch failed. It's hard to watch working on your own. When you have cured it the car will be much improved.
Post by: laney101 on 12 October 2015, 14:39:00
Cheers ill keepxyou posted on multiram
