Omega Help Area => Omega General Help => Topic started by: Suffolk Boy on 09 November 2015, 00:21:11
Title: DTI 2.2 Stutter.
Post by: Suffolk Boy on 09 November 2015, 00:21:11
I have a 53 plate CDX 2.2 DTI that has developed a strange problem, car starts well even after one week of standing, ticks over well, no hunting, but has now developed a miss fire when applying steering to left, I can cause this by weaving slightly from left to right  :(
On  left hand sweeps it feels like it is missing until I straighten up .
At the moment tank is half full , has  fuel filter changes every 5000 when oil and filter changed . Is run using Millers diesel additive and 200ml of two stroke to every 20 L diesel ,which I did for 60000 miles in Vectra C 2.2 DTI with no problems.
Will get a fuel filter change tomorrow.
Any advice or suggestions will be welcome  :y
Title: Re: DTI 2.2 Stutter.
Post by: 05omegav6 on 09 November 2015, 00:37:51
Is it when turning the wheel left, regardless of moving or not and starting position? ie s it the same if it's the last 1/4 turn of lock or if it's from full right lock?
What happens if you apply revs whilst turning the wheel left? Is it easier? Any strange noises?
Could be the power steering pump on its way out and increasing the demand on the engine :-\
Post by: Suffolk Boy on 09 November 2015, 00:52:16
http://www.omegaowners.com/forum/index.php?topic=112522.0
thanks for reply , I found this on forum so I will be having a look tomorrow.
Post by: Suffolk Boy on 09 November 2015, 13:56:35
 :y all sorted , pick up in tank gunked up with black sludge, wiped out and put back with new fuel filter under bonnet , bit fiddly and I need a new sealing ring  sooner or later for pick up in boot but I am a happy chap , thanks to original poster for highlighting problem :y
