Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: GastronomicKleptomaniac on 02 December 2015, 12:37:42
Title: Wtd - lower windscreen rubber.
Post by: GastronomicKleptomaniac on 02 December 2015, 12:37:42
Im after the rubber strip that clips across the lower edge of the windscreen... if anyone has one knocking about? :D
Title: Re: Wtd - lower windscreen rubber.
Post by: 05omegav6 on 02 December 2015, 13:19:37
The rubber or the metal frame?
Post by: GastronomicKleptomaniac on 02 December 2015, 15:00:30
The rubber strip, approx an inch wide, runs across the lower edge of the screen, along the top edge of the scuttle. Has two metal spring clip widgets on the ends.
The one on the MV6 was miasing so I borrowed the Special's  :)
Post by: 05omegav6 on 02 December 2015, 18:08:57
If it has metal springs then that's actually two pieces... metal frame AND rubber trim/seal. The rubber I might be able to help with, the metal is NLS...
