Omega Help Area => Omega General Help => Topic started by: tunnie on 14 December 2015, 08:53:03
Title: Clean Lazy Stat?
Post by: tunnie on 14 December 2015, 08:53:03
On the 2.2, I've noticed the stat is getting a bit lazy. Even after 20 mins at 50mph (M3 road works) it's still only at 80. Clear the road works, get to normal 80mph cruise and it's about 82/83.
Sometimes in stop/start work this morning, it does get up to 85 and stay there. But over the hour run to work, it's staying at 80 most of the time.
Normally it would sit bang on 85 all the time.
Is it worth taking it off, soaking it in Plusgas or something? As it does appear to open fully at times and stay there, just appears to be a bit "sticky"  :-\
Stat is around 85k/8 years old, was last changed at 100k.
Or is it just time for a new one? Reason to ask about cleaning, is it's very easily accessible unlike the V6.
Title: Re: Clean Lazy Stat?
Post by: Lazydocker on 14 December 2015, 09:18:58
Don't be so tight ::) ::) A few pounds will see a new stat fitted with less effort ;)
Post by: flyer 0712 on 14 December 2015, 09:52:20
On yours and others advice i changed mine because of it running around 82deg,,i bought a Quinton Hazel stat that came in a kit with gasket and a cardboard tube to use to release the stat from the housing all for around £15..along with heater flushing i can honestly say that in all my 10/11 omega 2.2 i have never had one that heats up so quickly and delivers so much heat within 2 miles as this one,,so with respect mr.tunnie..take your own advice and as said on here get your wallet out and buy a new one..treat yourself for Christmas...you know it makes sense ,,,cheers matey  ;D ;D ;D ;D
Post by: Gaffers on 14 December 2015, 09:57:38
I have similar symptoms with my 2.5/
Hey ho, I'll just add it to the list ::)
Post by: tunnie on 14 December 2015, 10:24:29
Yes I probably should listen to myself  ;D ;D ;D
flyer - Where did you get yours from?
Cheers  :y
Post by: robson on 14 December 2015, 11:01:59
Quinten Hazell havnt been around for a long time must have been old stock.
Post by: Field Marshal Dr. Opti on 14 December 2015, 11:38:47
Mr Tunnie has a reputation for being as 'tight as a ducks arse' with his money.
Can't think why. :)
Post by: tunnie on 14 December 2015, 12:01:44
It works some of the time, thought it was worth a go? Easy peasy to get access...
Post by: Gaffers on 14 December 2015, 12:40:32
Can't think why. :)
Pot....kettle.... ;D
Post by: Nick W on 14 December 2015, 13:10:39
At under a tenner for a new one, you would have to have more time than I do not to fit a new one. And I'm unemployed!
Post by: tunnie on 14 December 2015, 13:19:46
Fair do's new one it is  :)
Post by: tunnie on 14 December 2015, 13:25:58
Any good?
http://www.ebay.co.uk/itm/Vauxhall-VECTRA-OMEGA-SINTRA-ASTRA-ZAFIRA-FRONTERA-THERMOSTAT-HOUSING-NEW-/370097457985?fits=Model%3AOmega%7CPlat_Gen%3AB&hash=item562b870b41:g:WlYAAOSwq7JT6h22 (http://www.ebay.co.uk/itm/Vauxhall-VECTRA-OMEGA-SINTRA-ASTRA-ZAFIRA-FRONTERA-THERMOSTAT-HOUSING-NEW-/370097457985?fits=Model%3AOmega%7CPlat_Gen%3AB&hash=item562b870b41:g:WlYAAOSwq7JT6h22)
Post by: TheBoy on 14 December 2015, 17:16:09
Like anything off egay, nobody can answer. Christ knows what you will get.
If you're too tight/lazy to look elsewhere, take a punt, if its any good then happy days, if its shite, well, what do you expect from egay?
Post by: tunnie on 14 December 2015, 17:44:52
Getting to dealer is problem these days. Hence online....
Post by: aaronjb on 14 December 2015, 17:47:20
AGP?
(Just tried to check their website for you as I was feeling generous.. but I don't seem to be able to get it to do anything other than say "An error has occurred" after selecting the car)
Post by: tunnie on 14 December 2015, 18:18:11
Yeah already checked AGP, need to call them. Site never works too well, normally things listed under Opel.
I need to escape work on time and get to dealer.
On that subject does anyone have the part number? Cheers  :y
Post by: RobG on 14 December 2015, 18:36:46
90501081 is the VX Part Number for the complete assembly
Post by: TheBoy on 14 December 2015, 18:41:28
If you have TC, they should deliver - assuming you can guarantee someone will be in.
Post by: tunnie on 14 December 2015, 19:20:57
Thanks Rob  :y
Heathrow to Surrey/Hampshire border? Not sure they would go that far, plus TC account is not in my name  ::)
Post by: TheBoy on 14 December 2015, 19:45:03
Thanks Rob  :y
I don't know what your dealers are down there.
Your local TC dealer will deliver to your registered TC address.
Post by: 05omegav6 on 14 December 2015, 20:19:19
Now Vauxhall at West Byfleet are hardly out of the way :-X
Post by: flyer 0712 on 14 December 2015, 20:40:25
Quinton hazel were sold to Tetrosyl in 1963  and quinton hazel products are still available today,,,so not old stock.....mr.Tunnie i lied the kit cost me a mere £8.37 with free p and p.......still on flea bay on item number...271936226133....item part number Qth 600k...I have never had any problems with their products and actually use to work in the motor spares trade for Partco for about 20 years  during the 70s and 80s.... :y
Post by: flyer 0712 on 14 December 2015, 20:41:50
Sorry should have read...sold in 2013...its me age you know. ;D ;D
Post by: aaronjb on 14 December 2015, 20:59:13
Slowest parts counter in the known universe though, unless it's improved in the last couple of years..
Post by: tunnie on 14 December 2015, 22:08:44
Looking at it, that's just the stat. Did you re-use the original housing?
Post by: tunnie on 14 December 2015, 22:09:22
Vx Heathrow is on a roundabout on my commute. It's getting there before it shuts.  :)
Post by: flyer 0712 on 15 December 2015, 19:34:38
yep used original housing..no probs swopping stat with the cardboard tube they supply with kit,,easy peasey.. :y
