Omega Help Area => Omega General Help => Topic started by: Webby the Bear on 16 December 2015, 20:25:21
Title: Codes 133 and 31 on 2.5 V6
Post by: Webby the Bear on 16 December 2015, 20:25:21
Evening guys, hope you're all well :)
Got the check engine light come on about 20 miles from home today  ::) I had a paperclip and the internet so I managed to get the codes  :y
31 - EGR voltage low
133 - intake valve 2 voltage low
Luckily I think I have the answer.
I replaced my aux belt tensioner at the weekend. Being a ham-fisted oaf I broke the part that covers the wiring loom at the side that slides out...
Assuming ''intake valve 2'' is the front multiram valve and the wiring for the EGR meets in this loom I'm going to say that by not being able to put this piece of plastic cover back I've left the wires exposed to heat and these two have melted/broken??? Therefore, remove the loom tray, track the wiring, solder if necessary, get a new cover!
Unless theres something you think ive missed that's obvious? :)
Title: Re: Codes 133 and 31 on 2.5 V6
Post by: Webby the Bear on 16 December 2015, 20:26:01
ps, I looked at the front multiram and blipped the throttle.... nothing moved!  :y
Post by: TheBoy on 16 December 2015, 20:35:45
Check where its near aux belt :)
Post by: Webby the Bear on 16 December 2015, 20:36:56
will do mate.
hopefully its an easy solder repair.  :y
I take it ''valve 2'' is the front 'ram'?
Post by: TheBoy on 16 December 2015, 20:37:54
code 57 is rear one...  ...that I always forget to reconnect ;D
Post by: Webby the Bear on 16 December 2015, 20:43:31
 ::) ;D
ill cable tie them back until I can repair it tomorrow.
don't suppose you have a spare plastic piece that slides in (you know what I mean lol) that I can buy off you do you?
if not im sure we've got some wiring shroud and plenty of cable ties at the shop  :y
Post by: Webby the Bear on 17 December 2015, 21:01:01
Note to self. Make sure multi RAM plugged in before removing wiring loom and inspecting it all  ::)
Check engine light now out  :y
Just a quick question though. The front ram. Is this the one that opens after 5k rpm blip? Blipped throttle a few times but didn't move. Car seems just as powerful  :y
Post by: Webby the Bear on 18 December 2015, 12:06:27
anyone?
Post by: RobG on 18 December 2015, 15:44:40
anyone?
Should actuate around the 4K mark
Post by: Webby the Bear on 19 December 2015, 09:35:26
Cheers Robeena  :y
