Chat Area => General Discussion Area => Topic started by: EMD on 22 December 2015, 23:42:45
Title: LED lights
Post by: EMD on 22 December 2015, 23:42:45
Buying some outdoor LED xmas icicle lights , never put them up before but the product says ...
Suitable for indoor and outdoor use, although the transformer should remain indoors at all times.
Where would you put the power wire into the house ?  :-\ Was thinking through the window then close the window as long as that dont crimp the wire  :-\
Title: Re: LED lights
Post by: flyer 0712 on 22 December 2015, 23:47:18
If its an upstairs small window should be ok...... :y
Post by: zirk on 22 December 2015, 23:56:34
I normally use the same hole thats used for the Kitchen Supply thats connected to the Street Light outside. ;)
Post by: Gaffers on 23 December 2015, 07:18:56
I have one that goes out through a closed pvc window, has done for years without ill effect. You could also get a weatherproof box if you have an outdoor socket..
Post by: aaronjb on 23 December 2015, 09:17:56
 ;D ;D ;D ;D ;D ;D ;D ;D Are you related to STEMO? :P
Post by: Field Marshal Dr. Opti on 23 December 2015, 09:34:26
I believe he no longer lives in Liverpool. ;)
Post by: Nick W on 23 December 2015, 09:46:47
Then he must have stolen a long extension lead before he left!
Post by: EMD on 23 December 2015, 14:26:45
All sorted , power wire fed through the window no problem . All ready for the big switch on later  ;D  :y
Post by: STEMO on 23 December 2015, 16:34:46
Why bother putting a hole in your house? Just bypass the meter.  :)
Post by: Tony H on 23 December 2015, 19:27:27
Is right Steve  :y
