Omega Help Area => Omega General Help => Topic started by: gbh on 19 January 2016, 21:18:21
My headlight washer pump is kaput and i've thought about replacing it,but is it really necessary?
Do you have Xenon lights? If so, then the washers must work for its MOT.
Well I didn't know that and I guess the MOT tester doesn't either.As i'm driving a CDX it should have xenons fitted I suppose.Does anyone have a spare for sale?
Should have, will che k tonight and get back to you
Keith ABS
I know the general perception is that mechanics aren't very cerebral, however it is their job. ??? Keith'll see you right :)
Is the pump not working or is it just blocked....?
If you can hear the pump, Id suggest its just blocked....
If one jet works ... the pump works !!
It's a blockage ..nowt else .. :)
(or am I confusing threads ???
http://www.omegaowners.com/forum/index.php?topic=134168.0)
Don't headlamp-washer-equipped models have two pumps? One for screen and one for the lamps? As per...
(http://workshop-manuals.com/vauxhall/omega-b/images/omega-b-7026.jpg)
Just in case you hear a buzzing, but it's the other pump you're hearing... Pull the plug off one to confirm the headlamp pump is still working/dead?
H/L washer pump is red
(http://i190.photobucket.com/albums/z257/belisensis/ae1c22dc-15ea-44c6-b550-67531cb406c3_zps2df1a369.jpg) (http://s190.photobucket.com/user/belisensis/media/ae1c22dc-15ea-44c6-b550-67531cb406c3_zps2df1a369.jpg.html)
Why did I know Rob would be along with a picture any minute? :) Great stuff! :)
And here`s the pump in question ;)
(http://i190.photobucket.com/albums/z257/belisensis/P1050106_zps161920a6.jpg) (http://s190.photobucket.com/user/belisensis/media/P1050106_zps161920a6.jpg.html)
It's a daft question I know but you are checking them with the lights turned on aren't you?
Well I was sure but now i'll double check,assuming it works at the same time as screen wash? But i'm pretty sure its kaput and unplugged too.Now how would you ever know if it needed water?
Yes works at same time as screen washer[as long as headlamps are on]feeds off same bottle as screen wash,so if screen is getting washed so are headlights.I seem to remember being told that washer bottle is bigger capacity on cars with headlamp wash than on models without.Don't know how true that is though.
6.3 litres vs 5 ;)
Gives a short 1 second blast when you pull the front washer switch... But only when the headlights are on :y
One I have is the 090 586 631 pump, which I believe is the windscreen wash item
Keith ABS
Well I double checked today and its kaput so if anybody has a good one for sale I may well be interested!!
Fairly sure both washer bottles in my facelifts are the same, both 6.3L
Yep Tunnie..both the same..i just drilled out the plastic bit where the motor fits as marked on the washer tank and fitted what was required.. :y
I may well sell then :D
