Chat Area => General Car Chat => Topic started by: Jimbob on 06 February 2016, 19:04:26
Had a pair of new tyres on the mum bus in the week.
During REMOVAL! one of the wheel bolts sheared off.
Ive managed to remove the broken bit, which was seized in.
I now cant get a bolt to thread in.
Also, annoyingly wanted to MOT it next week and a missing bolt is a faulure I beleive.
Options.
1, silicone sealant the remaining external bit in the hole to get me through the MOT as time is awkward at the moment. (a very short term 'fix')
2, tap and die set to try and clean up the thread so a bolt will go in, trouble is I dont have the right size (M12 x 1.5 I think) or get garage to do this?
3, New wheel bearing, hub and brake disks and pads while im at it.
Any better plans or advice?
Take it to an engineering shop and have them run a tap through it.
Or, if the thread is knackered rather than dirty, new hub.
go and see my mate at AA Automotive and tell him i sent you and he will run a tap through it for you his name is Jim :y
Carefully running an M12x1.5 down any remaining thread is your best bet. If that doesn't work then a new is top of the list.
M12x1.5 is common on cars(wheel threads and fuel fittings mainly), but isn't the favoured metric thread which are either 1.75 or 1.25 so you will probably have to order one.
Cheers all, AA Automotive sounds like it could be a plan, Convienient local recommendation :y
It is dangerous to drive with less wheel bolts/nuts than manufacturer intended and I believe if caught you can get nicked for doing so?
I'd expect a lot of small garages to have the correct tap. When my lad was trying to be a clever clogs & run a wheel bolt IN using my windy gun he managed to cross thread one ..... as I said he would :-X ..... and a local garage lent me a tap
the M12x1.5 sounds about right ....... you can always take a bolt with you to match up :y
1. I wouldn't rely on silicone to keep the bolt head in place - chances are it will get flung out and through someones windscreen (& taking a vehicle for an MOT & deliberately trying to hide a serious fault is probably a criminal offence :-\)
2. I try not to use a tap in an existing thread until I can be sure it won't destroy the old thread by cutting a new one. I would be sat by the wheel hub with a rat-tail file carefully filing away the core of the old bolt until I was able to pick out the remains of the threads.
3. a new / second hand hub should be the last resort but might be the quickest way of getting going again.
.... I would be sat by the wheel hub with a rat-tail file carefully filing away the core of the old bolt until I was able to pick out the remains of the threads.
the remnants of the old bolt is out, Jim will be OK if he uses a 1st/taper tap :y
Not advised, but can be done in an emergency...
For the record, not looking to bodge, want it fixing properly, preferably on Monday.
Time extremely short currently as back and too hospital daily with my eldest, along side usual work and family commitments
Glue idea purely to get an MOT while I fix, and REALLY not a route I want.
Ive been left up the creek and trying to make the best of it.
Im sure the thread just needs a light cleaning up, my tap set has m10x1.5 or m12x1.75, so close, but so far!
Amazed how it happened, as I know it was put in correctly, to the correct torque, and removed with a bar, not gun.
Pull up to MOT station, stick some parcel tape over the hole. Fix at your earliest convenience. :y
If you are just looking to clean up the thread then you can grind a series of slots in a spare bolt (so that it looks like a proper tap) - using lots of lubricant (eg plusgas) work it in and out of the bolt hole and use it to clean the crud out of the threads.
Is it front or rear? Rear hubs are a sealed unit, held on with four bolts iirc... Fronts should just be the flange and possibly a new hub nut...
Tis the front
Tis the front
Undo the hub nut, caliper and disc off, pull the flange off...
Tap the new one on, bolt it all up..
Job jobbed :y
might be able to get the tap for tomorrow depends if my mate is going in to work will let you know :y
Cheers all!
Forgot to mention the other 'minor issue' - Garage door broke on me too, so tools very inaccessible, esp my jack!
Having one of those weeks are you...
You dont know the half of it!
I stand corrected re front hub assembly...
Try this...
http://m.ebay.co.uk/itm/Vauxhall-ASTRA-H-ZAFIRA-B-FRONT-WHEEL-HUB-BEARING-ABS-SENSOR-OEM-NEW-/141895215078?nav=SEARCH
Or...
http://m.ebay.co.uk/itm/2x-WHEEL-BEARING-HUB-ASSEMBLY-FRONT-AXLE-KIT-OPEL-VAUXHALL-ZAFIRA-MK-2-B-3-C-/371453729574?nav=SEARCH
Yea, the fronts are a hub assembly like on an Omega. Cost me £75 for aftermarket good brand when I had to do one on my Zaf A
Keith ABS
The CDTi front hub is a big beefy job and the same as used on the VXR, its not the 'standard' and more common one.
Amazed that broke though, if it was the OSF the bolts were run in by hand and then torqued up.
Is the thread actually damaged?
Cant really say on how damaged, I just know removing the last bit of bolt wasnt easy, and I cant thread a new one in now, hopefully just needs a tap running through to clean it up.
Its Passenger front, and not sure Ive ever taken it off in honesty
First one I linked too purports to be suitable :-\
Only reason it would have been previously removed would be if the bearing had failed...
That's odd. The behavior described usually occurs if the thread protrudes through and either goes rusty or gets damaged by striking something.
Are there any signs of a foreign body getting stuck behind the flange?
Well with huge thanks to b4ndit, I am now sorted.
He lent me a tap, which got the job done in seconds.
Not only that he had a spare wheel bolt which has saved me from having to use a locking bolt which I hate.
No signs of damage anywhere, guess it must have been 'windied' up to stupid torque once or twice before my ownership/
Job jobbed, well done b4ndit :y
