		Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: Vega on 09 February 2016, 07:52:25
				Hello,
 I am looking for the air pipes of a self leveling system saloon petrol.
 Pleas let me know if you have any?
 Peter
				If it helps, estate ones might fit... certainly the pipe from the pump to the T piece is the same ;) Also, they were readily available new... might be worth a phonecall :y
				Need pipes from T piece to shock absorbers.
 Estate is to sort.
 At the Opel dealer not available anymore.
				From memory I think its the same size as the vac pipes in the engine bay and if you only need from T peice to shock you should find then long enough.
 Be carefull if they are being sent to you as being quite rigid have a tendancy to crease :y
				I do have a new set in the garage, if saloon and estate are different do you have part numbers and I will check with what I have. :y
 That would be nice if you have any.
 90473520  4 37 690 PIPE, PRESSURE, 1140MM LONG SALOON 25, 26, 27, F69, M69, P69
 90473519  4 37 691 PIPE, PRESSURE, 500MM LONG SALOON 25, 26, 27, F69, M69, P69
 Looks like I do not have the above parts, my numbers are
 1x 90251877
 2x 90473521
 Sorry :-\
 1x 90251877
 2x 90473521
 These are for an Estate.
 Thanks for looking.
