Omega Help Area => Omega General Help => Topic started by: jimjimanta on 22 February 2016, 09:59:20
Title: repair top mount
Post by: jimjimanta on 22 February 2016, 09:59:20
i want a guide for the repair of top mount .
I searched the site , but i did not find.
Title: Re: repair top mount
Post by: trackcars on 22 February 2016, 10:28:07
Do you mean the top front suspension mounts?
Post by: jimjimanta on 23 February 2016, 13:45:05
sorry. yes front top mount .
Post by: Nick W on 23 February 2016, 13:52:50
In that case:
Remove the entire strut from the car.
Use robust, properly fitting spring compressors to safely compress the spring. This is the important part of the job, you can badly hurt yourself using poor equipment.
Undo the nut on the top of the strut.
Remove the top mount and bearing.
Replace them with new; I doubt you'll see any damage to the top mount until you compare it with a new one - they compress in use.
Tighten the top nut.
Refit the strut.
Post by: trackcars on 24 February 2016, 17:58:25
That's right I removed mine which looked ok but when compared they were definitely more compressed
