		Omega Help Area => Omega General Help => Topic started by: swordfish on 23 February 2016, 20:21:51
				 2.6 mv6 auto ,  drives ok then out of the blue it will start to slip .. if you stop and turn off the car for 5 to 10 seconds and start again all is well again   :-\ :-\   anybody any  ideas . thanks
				Fluid level...
				 to high or to low
 to high or to low
Have you read How to check the autobox fluid level (http://www.omegaowners.com/forum/index.php?topic=90508.0)?
It isn't going to be too high & if someone has tried to check it without the engine running it will be too low.
				Yep, check the fluid level (on the flat, with engine running) and condition soonest. If the fluid is black, smells burnt, or the level is significantly above normal, the fluid needs changing (it expands as it ages). Drop both the gearbox sumps to drain the fluid and check for debris in the sumps while you're at it.
				 :y :y
				Don't forget to remove and clean the little magnet that WILL be covered in a grey sludgey crap...
I did mine about 2 weeks ago, the oil that cam out was very very black and smelly, the stuff thats in now is very very red - but still stinks LOL
