Omega Help Area => Omega Electrical and Audio Help => Topic started by: raywilb on 08 March 2016, 22:18:02
I have a couple of dash bulbs that are not illuminating. ive seen the how to but does a battery lead need to be removed. I see the warning not to turn ignition, so I'm guessing not :-\
The fool proof way is to remove the earth lead from your battery, that way you can turn the ignition key as many times as you want without triggering the airbag/SRS light. But you don't need to if you don't turn the ignition when the clocks are out.
No need to disconnect battery - as said, as long as you don't turn ignition on ;)
