Omega Help Area => Omega General Help => Topic started by: pauls on 11 March 2016, 21:57:05
Title: wheel alignment
Post by: pauls on 11 March 2016, 21:57:05
Going to try a new place near me that has installed the same stuff as wims.. But just to help them out has anybody got the right setting for toe in/out, castor etc. I seem to recall that the general green area for omegas isnt good enough.
Title: Re: wheel alignment
Post by: 05omegav6 on 11 March 2016, 22:13:20
Front. :y
Toe in 0°05"
Camber -1°10"
Rear.
Toe in 0°06"
Camber -1°35-45"
Thrust angle 0°00"
Rear settings are a compromise as there's only one adjustment... but the thrust angle MUST be zero
Post by: pauls on 11 March 2016, 22:19:03
Cheers Al, i found your other post on this but couldnt see your results.
Post by: Steve B on 11 March 2016, 22:57:09
Front. :y
Toe in 0°05"
Camber -1°10"
Rear.
Toe in 0°06"
Camber -1°35-45"
Thrust angle 0°00"
Is that for all F/L Al
Post by: 05omegav6 on 11 March 2016, 23:05:37
All Omegas, although MV6/lowered should have a front camber of 1°15" :y
Post by: tunnie on 11 March 2016, 23:16:34
Where are you using? Be good to hear feedback  :y
Post by: TheBoy on 12 March 2016, 10:34:08
There's a place local to me with Hunter DSP stuff.  But sadly, after speaking to them, they don't understand what they are doing with it.
Post by: pauls on 18 March 2016, 16:23:38
Just had this done today.
Company was Pitstop tyre centre unit 27 clayton road hayes middlesex ub3 1du.
It took them a while about 2hours but that was due to everything solid and not willing to move. Lots of spray and heat so work could begin.
Measurements not 100% to list below but a lot better than it started with also a straight steering wheel now.
before front -2.32....-2.09 camber
                        5.05....4.58  caster
                        0.18......0.15  toe
Back               -1.49......-1.49 camber
                        0.27.......0.19 toe
                          0.04 thrust angle
now    front -1.13  -1.12 camber
                     5.13...5.00 caster
                   0.05..0.05 toe
back       -1.57...-1.50  camber
               0.06.....0.05  toe
                 0.01 thrust angle..
As you can see not perfect but a lot better and only £60 all in.
Post by: Kevin Wood on 18 March 2016, 16:29:47
Looks pretty good to me. :y
The setup at the rear will always be a compromise between camber and toe.
Post by: 05omegav6 on 18 March 2016, 16:32:59
At that price that's impressive :y nearer than wim too...
Post by: cwill144 on 18 March 2016, 16:57:08
Best place I've found and do a good job is :-
Blackboots and Wheels in-Motion
Chesham Branch and Head Office
33 Chess Business Park
Moor Road
Chesham
Buckinghamshire HP5 1SD
Telephone number is 01494 797820
Email: sales@blackboots.co.uk
I used them about a year a go the did a really good job and tyre are wearing evenly now.
Post by: VXL V6 on 18 March 2016, 17:23:47
Moor Road
Chesham
You'll also get a 15% discount if you mention OOF.  :y
Post by: iansoutham on 18 March 2016, 18:58:34
I must disagree there. I have been there twice (driving all the way from Kent) and have never received a discount either on the Omega or on the Audi (which was full alignment and a tyre)
Post by: YZ250 on 18 March 2016, 19:05:57
Maybe it's who you see but despite mentioning OOF several times I never got any discount.  :'( :'(
Post by: ted_one on 18 March 2016, 19:12:36
I recently took the two lowered cars to ATS for the alignment and was told that they could'nt do either car due to the lowering and the Irmy bumpers, so I took them to Merit Tyre who use the John Beam system....done without a problem, job's a good 'un :y
Post by: VXL V6 on 18 March 2016, 19:18:40
Hmmm, must be who you speak to I guess.  :-\
I must admit I hadn't used them for a few years until recently (Last two times and two cars because I was working local to them and could leave the car there), they got my first Omega set up nicely but the ones in between where setup at a more local place due to time constraints.
If your trying to work that out, I've had six Omega's and a seventh will appear soon!!!  ::) ;D
Post by: pauls on 18 March 2016, 20:06:30
Moor Road
Chesham
Buckinghamshire HP5
I went they and wasnt that impressed no discount and still had to go back twice for the steering wheel not straight and cost me twice the price
Post by: dbug on 18 March 2016, 23:58:20
Good to hear WIM discount to OOFers is so readily available ???  Not a great incentive
Post by: frostbite on 19 March 2016, 12:41:56
Are those settings what the police used?
