Chat Area => General Car Chat => Topic started by: biggriffin on 14 March 2016, 07:04:12
Title: Halfords again.
Post by: biggriffin on 14 March 2016, 07:04:12
Halfords have an extra 15% off tools again, so fill up what's needed,  ratchet scanners £34.00,
So basically 65% off all advance tools :y
 http://www.halfords.com/workshop-tools (http://www.halfords.com/workshop-tools)
Title: Re: Halfords again.
Post by: ronnyd on 14 March 2016, 09:16:31
What the hell is a ratchet scanner? ???
Post by: TheBoy on 14 March 2016, 09:21:40
Spanner
Post by: Sir Tigger KC on 14 March 2016, 09:23:54
He's been eating sugar beet again!  :P  ;D
Post by: TheBoy on 14 March 2016, 09:25:02
Ooooo, in the market for another 200pc socket set :) :y
Post by: TheBoy on 14 March 2016, 09:28:05
Still cheaper on trade  :'(
Post by: ronnyd on 14 March 2016, 09:28:56
;D ;D ;D ;D
Post by: biggriffin on 14 March 2016, 09:32:46
What you done with other one, not had it 10minutes.
Post by: biggriffin on 14 March 2016, 09:34:16
Please sir that Tigger's picking on me. :) :D
Post by: TheBoy on 14 March 2016, 09:47:05
Its decanted into trays that go in the tool chests. So when you need to sling one in the boot, its a PITA.
Besides, as arronjb implies, you can never have enough shiny tools ;D
Post by: biggriffin on 14 March 2016, 09:52:58
Fair enough on both points. :y
Post by: aaronjb on 14 March 2016, 09:58:13
Which is how I ended up with not one but two Myford lathes.. ;D
Post by: ronnyd on 14 March 2016, 10:40:34
So now you have a 4axis m/c or one for each hand.
Post by: Nick W on 14 March 2016, 10:46:33
Saves multiple setups when doing batches of parts, or changing chucks.
Post by: aaronjb on 14 March 2016, 10:56:35
 ;D ;D
Well.. it would if I would pull my finger out and get them both working again - they both really need a rebuild and in reality I ended up with two because one has the screw-cutting gearbox and the other has the drive-spindle clutch.. converting the former to three phase with soft-start and speed control would really do away with the need for the clutch, though.
IIRC one is 1970s and one is 1950s with the older model being in better condition.. they really both need at least new bearings and one might even need a new leadscrew as it has quite a lot of backlash.
</drift>  :-[
Post by: EMD on 14 March 2016, 13:25:43
Still not cheap enough , dont even do a 99p single spanner  :(
Post by: TheBoy on 14 March 2016, 18:27:21
I can sell you some 99p spanners. Obviously they are shite, will fail, and will hurt when they fail.
Post by: Viral_Jim on 14 March 2016, 19:03:06
This. I upgraded after popping 2 sockets in 1 day on a cheap set (laser maybe). Lost most of the skin on the knuckles of 1 hand. After that, the Halfords Professional sets looked pretty reasonably priced.
Post by: YZ250 on 14 March 2016, 20:41:25
They've improved the hinges and catches on the later cases as well.  :y
Post by: TheBoy on 15 March 2016, 09:21:31
All the Halfords Pro/Advanced sets I've owned have either been too old or too new for those shitty cases, but I've seen other members' ones.  Only minor annoyance with the new ones is the side catches, plus I also have concerns about long term use of those catches...
Post by: YZ250 on 15 March 2016, 16:14:35
By improved, I mean that the lid actually stays connected to the base via the hinges when you fully open it (metal pin), whereas on mine the lid falls off when you open it (plastic lug). Can come in handy if you only require one half of your socket set I suppose.  ::)
