Chat Area => General Discussion Area => Topic started by: Jimbob on 19 April 2016, 08:56:12
Title: Hi-Lo Pir Availability
Post by: Jimbob on 19 April 2016, 08:56:12
In need of a new PIR.
We have had for years, a hi-lo type.  Come on at dusk, at set dim level, when pir triggered, goes to full brightness, then back to dim again.
These were readily available years ago when I fitted it.
Now, can I find one, can I hell?  Anyone seen them recently?  or know why they seem to have vanished?
Title: Re: Hi-Lo Pir Availability
Post by: zirk on 19 April 2016, 09:23:52
Something like this, or are you after the spot light type.
http://reviews.homebase.co.uk/1494-en_gb/737685/reviews.htm
Post by: Jimbob on 19 April 2016, 10:00:29
yes...and no...
That is the end result, but due to driveway shape etc, that type spend all their life on.
I run a lantern like that, but with a separate pir some distance away so it works as it should...
Its the standalone PIR im after, but they do not seem to exist anymore.
Off out with a screwdriver to see if it can be fixed.
Post by: b4ndit on 19 April 2016, 11:02:31
is it like this
http://www.lyonlighting.com/pir180bk.html
Post by: zirk on 19 April 2016, 11:06:37
I think Jimbob after a Dusk to Dawn one with Hi Lo brightness if triggered by the PIR.
Post by: tigers_gonads on 19 April 2016, 11:18:27
Just to clarify ..............
Do you want a stand alone PIR with Hi-Lo capability of do you want one with a light fitting attached ?
Post by: Jimbob on 19 April 2016, 11:37:21
Cheers,
Looks like Ive managed to fix it...those things arent designed to come apart...
i'd adjusted the sensitivity to work in the day to test if it worked with a new dimmable led   (it does)  but on putting the sensitivity back the scre just spun.
On opening it up, could get a spline drive to grip to turn it.  All back together and working.
For clarification, it is / was a stand alone pir, with dawn to dusk, but coming on dim all night, going to full bright when triggered.
Cheers
Post by: b4ndit on 19 April 2016, 11:38:32
 :y :y
Post by: Bigron on 19 April 2016, 21:40:25
Jimbob, what device do you actually have - any link?
Mine is bog standard, either on when triggered, or off. And of course off during daylight.
A two-level illumination would be quite neat.
Ron.
Post by: Jimbob on 21 April 2016, 09:22:43
Ron.
If I could find a link you'd be welcome to it...
Variety of hi-lo devices here : http://www.scldirect.co.uk/security-lighting/p-lux-hi-lo-wall-lights.html
