Omega Help Area => Omega General Help => Topic started by: Dan282 on 23 April 2016, 18:20:50
Hi all. I'm currently trying to change the 2-3 soloniod. Does it does unclip from the wire and pull out or do u have to do anything else? Currently have gearbox sump and filter off.
Cheers :)
un-plug the wire, remove the roll pin and then the solenoid will pull out.
When I did mine I could not remove roll pin and ended up removing the whole valve body.
I have pictures of it all in bits if you need them.
Steve
had replace 2 or 3 of them solenoids and all ways was problem with removing pins
imho its quicker replace gearbox
If you have to drop the valve body - note the 2 ball bearings - do not drop them and lose them!
(http://i429.photobucket.com/albums/qq19/steve6367/Omega/th_2015-10-252013.43.41_zpsecraqcuj.jpg) (http://s429.photobucket.com/user/steve6367/media/Omega/2015-10-252013.43.41_zpsecraqcuj.jpg.html)
As Serek says, not hard to drop the box if you want to work on it on the bench - I thought I would not be able to do it, but managed it ok on the drive. Mine had a failed thrust washer so had to come off.
(http://i429.photobucket.com/albums/qq19/steve6367/th_63242e2f3d4df06ed5c0793f2b564353_zpsg7ta9neh.jpg) (http://s429.photobucket.com/user/steve6367/media/63242e2f3d4df06ed5c0793f2b564353_zpsg7ta9neh.jpg.html)
All sorted thanks guys. I needed to get some mole grips on the pin and it came out reasonably easy in the end. Thanks :y
