		Omega Help Area => Omega General Help => Topic started by: Bigron on 28 April 2016, 15:55:51
				A fairly trivial problem, gents, and one which may be more in my perception than real, but said display is becoming hard to read in daylight and impossible when the sun is out. I am SURE - in my head, at least - that it was brighter once! Is it possible that the bulbs dim with age; they are tungsten, yes? Would it be a simple job for a simple bloke to replace them?
Ron.
				Bulbs could have gone, mine has been operating on 2 bulbs for years, still easily read in normal light but bright light can be an issue.
They have 4 bulbs in there, so worth putting 4 new in  :y
				I have the same problem was looking through the forum and came across this link which show how to remove the MID /TID display and it shows where the bulbs are. http://www.omegaowners.com/forum/index.php?topic=90666.0 (http://www.omegaowners.com/forum/index.php?topic=90666.0)
				Turn it up on the adjuster by the light switch maybe  ::)or new bulbs :y
OP said it was difficult to read in daylight so I suggest the lights were off and the adjuster won't make any difference
				http://www.omegaowners.com/forum/index.php?topic=90644.0
http://www.omegaowners.com/forum/index.php?topic=90618.0
				Thank you, gents. At least it's possibly not madness on my part and the display really is less bright now!
When I am brave enough I'll go for it. Some time ago I seem to recall a topic on here regarding substituting LEDs for the tungsten bulbs - is it worth considering?
Ron.
				I found the Range  sell the grain of wheat bulbs for cheap.
Worth a thought
				Does anyone know the type of bulbs are fitted, part number etc.
				Ebay item No. 321942346180
3.99 for 10
				Thanks frostbite
				i replaced mine with  t5 led
bulbs much brighter also replaced the bulbs in the clocks with t10 501 led bulbs at the same time
				"beefyecosse", I'm tempted to do just that myself, but I'm getting confused - an easy thing to do! Some say the bulbs are T1, others reckon they are T5  ???
On ebay, the LED lamps are offered in white and a range of colours; to preserve the standard appearance, should I choose white or amber?
TIA.
Ron.
				i used white led bulbs all round all my interior lights are led aswell www.ebay.co.uk/itm/10pcs-12V-0-2W-T5-1-LED-5050-SMD-Instrument-Panel-Bulb-White-Holder-/311374434568?hash=item487f5cd108 (http://www.ebay.co.uk/itm/10pcs-12V-0-2W-T5-1-LED-5050-SMD-Instrument-Panel-Bulb-White-Holder-/311374434568?hash=item487f5cd108) these are the ones i used in the info display
				Thanks for that - a very good price at 10 for £1.99 inc. delivery!
The usual Hong Kong delay, but I'm in no hurry.
Ron.
				I thought I had this problem. But was simply the brightness adjuster by the fog lamp switches I had moved by accident. Worth just checking it's up to maximum.
				Yep, I checked! Does that control work on daylight running anyway?
Thanks for the thought though; I've ordered those LED lamps and will have a go at fitting them when they eventually get here.
Ron.
				Can anybody else smell the disappointment already?
On the upside, its only about 5 mins work to replace them again.
				Ah, I know those 5 minute jobs, TB; shouldn't take more than an hour or two, then?   ;)
Ron.
Ron.
6 screws, that's all ;)
				I did look at the guides and it does seem as simple as you say, so when the LEDs make it all the way from Hong Kong I'll go for it!
I have a minor additional problem in that the left hand speedo illumination disappears, remedied in the traditional engineering way of clouting the glass with my knuckle; would I get access to the relevant bulb easily, too?
Ron.
				when you take the instrument cluster out look for the larger bulb holders these are for the backlight bulbs i used some t10 501 ledwww.ebay.co.uk/itm/CAR-SIDE-LIGHT-BULBS-CANBUS-ERROR-FREE-T10-501W5W-8-SMD-LED-XENON-ICE-BLUE-WHITE-/301908128523?var=&hash=item464b20730b:m:msfXXnQKXRvRNg0NlVcEEZg these are much brighter and draw less power than the standard 3w bulb
				Thanks, I've just ordered them - 10 for a fiver!
Ron.
Ron.
Oh dear. Still, its easy enough to change them back to proper bulbs once you realise that LEDs simply do not work satisfactorily in Omega dashboards ;)
				Why, what's the problem, TB? Not a huge cost if I have to throw them away, but don't they fit, or dim properly?
Ron.
				I went to europarts as they have them starting at 29p +vat each. i just had £2 in change & the guy gave me 6. have not put them in yet. i thought i may have been pulled over no restraint light as it was an advisory last year, but it was not mentioned for this years.
Que?  ???
Ron.
the dash was designed for normal filament bulbs that have a wide spread of light. led's give a comaparitve narrow spread of light
Ron.
I changed to LED on a Corsa (heater controls) and was very disappointed  the correct bulb gave much better light.
				Even these, Andy -  Ebay item No. 301908128523?
They have 8 SM LEDs to give all-round coverage, reportedly.
Ron.
