Omega Help Area => Omega General Help => Topic started by: onion on 19 May 2016, 12:57:32
Title: Engine oil change
Post by: onion on 19 May 2016, 12:57:32
  Another topic:
  I plan to shortly do an engine oil change (Omega 2.2 petrol, 2003, auto).
  Just wondered what the current thinking is on using engine flush for the 2.2 petrol ?
Title: Re: Engine oil change
Post by: terry paget on 19 May 2016, 13:52:25
I do not flush my 2.2s, nor any other Omegas. However I always drain the oil hot, removing the drain plug and allowing 15 minutes to fully empty. I change the filter every oil change. I change the oil every 4000 miles.
Post by: baggers on 19 May 2016, 16:58:15
Using an engine flush can be risky.  Basically it all depends how clean the engine is in the first place, the engine flush does a good job but all the crud it loosens ends up blocking the oil pick-up and starving the engine of oil, on the other hand I know of some people who use it regularly and the engine is very clean and has never been allowed to become dirty.
What I do is run some 10/40 for 100 miles and sometimes do it again then put the oil in that I want until next service. I also change the oil every 3-3500 miles and all my engines look like new inside including one that's done 140,000 miles.
Can't beat regular oil changes.
Post by: TheBoy on 19 May 2016, 23:21:42
Rather than an engine flush, if the oil is manky, just do some quick changes, eg every 1000 miles for a couple of changes...
Post by: omega2018 on 20 May 2016, 00:01:44
agreed, or if you really want to clean it now do a change with cheaper brand oil and change it again with nice stuff.
Post by: onion on 20 May 2016, 13:23:44
  ok, thanks all for the advice.
  Will probably do a follow up oil change in a couple of thousand miles, no engine flush !  :y
