Chat Area => General Discussion Area => Topic started by: TD on 19 June 2016, 18:40:51
Was dragged out of my shed this afternoon, for the first cut of the year for probably 2ft high grass ::) ;D
Started after a couple of pulls, like it usually does :y and cut the grass...
But I did wonder about having a go at sharpening the blade on it....having acquired a bench grinder.
Now I seem to remember theres something about turning a 4 stroke mower over.....something about the oil in the sump ....
Is it you can lift it from the handle upwards, but not side to to side :-\
My mower dumps its oil, no matter which way you turn it. So I angle at about 45 degrees (so it doesn't leak), to remove blade.
It cut the grass. Leave it alone.
Electric mowers don't leak oil. :y
My electric mower is sh1te, but the grass needs to be fairly dry & not too long for my ancient Atco petrol mower so it's often not used
I,ve got a new Flymo Easi Glide. What a pile of sh*t, it rattles like a can, the build quality is rubbish and feels like it,s going to float away,( i have to put a brick in the grassbox). ::) God i miss my old Compact 330, wish i,d have replaced the motor on that instead, though that was more expensive the this new one. :o
What was I thinking! Sound advice Steve :y
Have treated myself to a self propelled petrol mower,problem is IMO that.... engine + wheel on each corner but no frigging brakes,can't be right...having a problem with'operational contact' with any thing that gets in the way :o
That doesn't sound right. Funny, in a sit com kind of way, but not right. ;D
I use a Bosch Rotac 32. Plug it in and I'm off! It picks up the cuttings efficiently, leaves stripes behind and there's no mucking about with petrol or oil! :y
The only gardening jobs I do are the ones involving petrol and oil. ::)
Reminds me. Must make some progress on the petrol fired weed killer. :D
I concur. The only electricity new a mower should be HT.
I'd never have another leccy mower, universally useless - the grass needs to be dry and short, else it won't cut.
Tell us more....Sick of using weedkiller
Get a goat :y
Get a goat :y
2 stroke or 4 stroke? Like I say, I only do petrol powered gardening. ;)
