Chat Area => General Car Chat => Topic started by: Migv6 le Frog Fan on 23 June 2016, 11:32:50
What is the current thinking on the best source for these ? Istr genuine are prohibitively expensive, so some kind of aftermarket is the best option, but which one ?
Tia.
Bosch?
OEM ones are made by them anyway.
IME, Bosch unit is 30-40% cheaper that GM OEM one.
Try
vauxhallworldparts.com (http://vauxhallworldparts.com)
Site says "domain name will be up for sale from 04/16". Looks like they may have shut up shop ? :-\
Will try giving them a call tomorrow.
Working okay for me :y
And me
http://www.vauxhallworldparts.com
Ignore that, been there for months,
still trading fine, :)
Cheers. :y
Cheers. :y
They haven't got any, I checked. ;D
Is there any issue converting to the earlier coil pack? Fairly sure someone did this. Except for the different shaped holes in the rocker covers, I can see this being the way to go. 'Proper' HT leads will be made for the next fifty years. They can be made in a shed. :)
Er no......you have 6 firing pulses on the coil per plug setup and 3 on the DIS setup.......so as much as you might be able to with diode ORing its not guaranteed to work and the ECU might have a hissy fit
I wouldn't even attempt it tbh. Just want to source a good quality 246 pack for the best price. :y
Thought it had been done. If I don't ask I don't learn. Fair enough. :D :)
And me
If you read what it says in the red box at the top of the page - "domain will be up for sale....."
Site says the part I want is available for trade customers ? ???
Sent them a message - no answer.
Called the phone number - no answer - stuck again. :(
Just noticed this. Will kepp trying them, thanks. :y
Take your pick:
http://www.sparepartstore24.co.uk/oen-9118115
Thanks. :y
