Chat Area => General Discussion Area => Topic started by: TD on 26 June 2016, 17:47:15
Title: The dont make new fridges like they used to.....
Post by: TD on 26 June 2016, 17:47:15
And I'm glad!!!
Took my mum shopping for a new fridge this afternoon.
Two rows of fridges on display.....but only two that were 55cm wide and didn't have an ice box in them!  :(
Anyway chucked new fridge in the back of estate.....and away we went. :)
Unpacked the new fridge on her driveway.....now to take the old one out...
Old fridge must have weighed nearly twice as heavy....I picked it up only to put it down a damn sight quicker than I picked it up.....
So I dragged it outside and just managed to get in the back of my estate.
New....easy peasy.....picked it up easily and placed carefully down  :y
So my mum now has a working fridge again and on the upside, when I took her old one to the tip, the guy directing two long lanes of queues, let me queue jump to the front and another guy at the tip came over to help me unload it  :y
Title: Re: The dont make new fridges like they used to.....
Post by: STEMO on 26 June 2016, 17:56:40
I was under the impression that really old fridges had to be disposed of in an environmentally friendly way because of the CFC's they contain. A lot of tips wouldn't take them a while ago.
Post by: TD on 26 June 2016, 18:02:21
Probably why it didn't work anymore.....leaked away maybe....
But thats why I got queue jumped, you are not allowed just to chuck in a skip for landfill......they go in a designated area that I guess an approved contractor comes to take away and sucks out the CFC's into a bottle before crushing em  :y
Post by: STEMO on 26 June 2016, 18:04:55
Nowadays it's global warming. But do you remember when fridges were destroying the ozone layer and letting the sun melt the North Pole?  ;D
Post by: Sir Tigger KC on 26 June 2016, 18:15:46
I used to work for a transport firm that had a contract with Curries to collect all the old fridges they swapped on delivery.  We'd take them back to the yard and a Romanian firm came a collected them for repair and resell back in Romania.  :)
Post by: zirk on 26 June 2016, 19:43:32
You know that you are suppose to leave a new fridge in the upside position for 24 hours before you switch it on, if its be moved horizontally.
Post by: omega2018 on 26 June 2016, 20:07:00
is the make of the new fridge 'Bush'?  if so you'll be doing all this again in 12 months plus 1 day :(.
Post by: Crazycarzowner on 26 June 2016, 20:08:17
Someone said that about our double oven 5 1/2 years ago......... :-\
Post by: omega2018 on 26 June 2016, 20:09:59
i don't think even 'Bush' could f*** up an oven what is there to go wrong?
Post by: Crazycarzowner on 26 June 2016, 20:13:03
Could say the same for a fridge. Ovens heat hings up , fridges cool em down.
Post by: omega2018 on 26 June 2016, 20:21:36
no moving parts in an oven...
except if it has a fan or clockwork timer.
'Bush' could f*** those up I suppose :(
Post by: STEMO on 26 June 2016, 20:27:55
My mother has a Bakelite bush radio which still works. I believe her favourite station is Hilversum.  ;D
Post by: Bigron on 26 June 2016, 20:52:13
Stemo, your mother's radio was made in England, properly, and made to last.....
Ron.
Post by: Andy H on 26 June 2016, 20:55:57
While CFCs were still in general use the foam insulation was filled with CFC gas as a blowing agent. Vacuuming the gas out of the pipes is the simple part. Recovering the gas from the foam is a different task altogether. I don't think it is as simple as just crushing the thing :-\ https://www.gov.uk/guidance/recover-f-gas-when-disposing-of-equipment-and-insulating-foam (https://www.gov.uk/guidance/recover-f-gas-when-disposing-of-equipment-and-insulating-foam)
Post by: TD on 27 June 2016, 06:08:43
True if the fridge has been used, new fridges/freezers are ok to turn on straight away iirc
Post by: Andy H on 27 June 2016, 07:54:20
The basic technology hasn't changed - just the gas that is used as a refrigerant.
If the fridge lays on it's back for any length of time then both liquid refrigerant and compressor oil can find their way out of the compressor housing and into the network of tiny pipes. The reason for leaving it standing is to let the liquid & oil drain back into the compressor. (The risks being that the compressor may run without lubrication and that a slug of liquid might find it's way into the compressor.)
Post by: ronnyd on 27 June 2016, 11:01:47
Had a new freezer delivered a few weeks ago and the guys said,( after they took it upstairs, kitchen too small), to let it stand switched off for 12 hrs before i used it. :y
Post by: tidla on 27 June 2016, 17:57:59
Another pointless legislation made by people in power without a clue.
When ever you see a fridge on the street put there by the  ill informed, the scrap collectors just cut out the copper element in the back of the fridge and leave the case. What happens to the gas then..
Similar to the number plate legislation that came out. dig out all that paperwork and go to an approved number plate maker..
Post by: omegod on 27 June 2016, 19:31:29
The motors are quite desirable in the scrap world I believe
Post by: Rods2 on 27 June 2016, 23:42:39
Repaired several ovens for family and friends. It is normally the  elements and fans that go and also on drop down doors the hinges where heavy items are stood on the door which strains the hinges, so the door doesn't shut against the seal at the top.
