Omega Help Area => Omega General Help => Topic started by: Shackeng on 04 July 2016, 16:09:02
What gaskets do I need when replacing the thrust washer?
For info JPAT do the washer for £19 plus VAT for OOF members.
only gasket you may need is the paper/card one which is revealed when you lift away the bell housing with the pump attached, there is also a large o ring seated around the pump where it meets the bell housing. Didn't replace mine as they seemed ok & no leaks as yet oh & gaskets for sump pans :y
Cheers Razz :y
