Chat Area => General Car Chat => Topic started by: annihilator on 16 July 2016, 22:03:10
looks like amazon are having a sale on older stock car parts,just picked these up for spares
Magneti Marelli MM1199K1 Timing Belt Kit
£37.41
Quinton Hazell BFK346 Brake Shoe Fitting Kit
£5.49
VEMO Crank Sensor, flywheel V40-72-0357
£7.16
Sachs 3000951060 Clutch kit
£12.93
Nissens 63073A Radiator, engine cooling
£20.29
TRW DF2645 Front Brake Disc kit
£7.37
Mapco 15852 Rear Brake Disc, Set of 2
£8.54
Fuel Parts CU1004 Ignition Coil pack
£6.34
Magneti Marelli BSS2019 H/Brake Shoe kit
£5.54
still some bargains to be had air con. compressor £18.20
https://www.amazon.co.uk/Hella-8FK-351-102-051-Compressor/dp/B00BNYMX3E/ref=sr_1_4?s=automotive&ie=UTF8&qid=1468702848&vehicle=117-1560-1930-8118-1-0&sr=1-4&keywords=compressor (https://www.amazon.co.uk/Hella-8FK-351-102-051-Compressor/dp/B00BNYMX3E/ref=sr_1_4?s=automotive&ie=UTF8&qid=1468702848&vehicle=117-1560-1930-8118-1-0&sr=1-4&keywords=compressor) :y
John.
John.
That's a bargain ...... :y
Good timing i'm in need of a new Compressor, Ordered :y ...Will just have to wait and see if Amazon honour the deal.
Thanks for the heads up John :y
I put it in my basket and 5 minutes later it went up to £205.55. ::)
So it has :o
It did say there was only one left, Now says 7 left at £205.
(https://s20.postimg.org/m8lw6yhj1/a_c_comp.jpg)
No reason for them not to honour it,as they are all mostly last one in stock and not pricing errors.not just omega stuff either look on hotukdeals for more info.
John.
Thanks for the heads up . Ordered well over £200 worth of parts discounted to £43 :)
not for omega though :-X
Might be of use for someone with a diesel Omega, if not their selling for around £400 on eBay. https://www.amazon.co.uk/gp/aw/d/B009QXBAXS?pc_redir=T1&redirect=true&tag=ho01f-21 one available for £117
Got a bran new rad for £10 :o Then the day after its listed for £83 :o :o :o
How are you finding these bargains on amazon??
Received a new Bosch MAF for a 3.2 for £5 yesterday. Was taken back a little. Wouldn't even get a used one for that!
One way I found was to enter what you want, Select price low to high and select delivery via prime. Most of the good stuff has gone but there's some stuff out there especially for less popular cars.
These are for the Omega apparently, Worth double checking though.
ABS 250110 Tie Rod Assembly https://www.amazon.co.uk/dp/B00CPNYOUW/ref=cm_sw_r_cp_api_4xJKxbS0WW531
FAI AutoParts SS5013 https://www.amazon.co.uk/dp/B00B3U5ZEW/ref=cm_sw_r_cp_api_-yJKxbZ66T1N8
Fuel Parts MAFS037 Air Mass Meter https://www.amazon.co.uk/dp/B009R1DDXY/ref=cm_sw_r_cp_api_EzJKxbSTPAJVC
ABS 429611 Brake Caliper https://www.amazon.co.uk/dp/B00CPO3TQG/ref=cm_sw_r_cp_api_fAJKxb36KMHRG
ABS 422602 Brake Caliper https://www.amazon.co.uk/dp/B00CPNZ7J4/ref=cm_sw_r_cp_api_CAJKxbR0XXPWG
ABS 210417 Track Control Arm https://www.amazon.co.uk/dp/B00CPOD1YQ/ref=cm_sw_r_cp_api_TAJKxb0PVAA5H
Magneti Marelli 1848G Rear Gas Shock Absorbers https://www.amazon.co.uk/dp/B00D75YB9G/ref=cm_sw_r_cp_api_eBJKxbBYKNP2A
ABS 41865 Master Cylinder Brakes https://www.amazon.co.uk/dp/B00CPNR2J2/ref=cm_sw_r_cp_api_YBJKxbSV7BWF2
BOSAL 283-205 Middle Silencer https://www.amazon.co.uk/dp/B0068MULLC/ref=cm_sw_r_cp_api_jCJKxb9AZMYH8
ABS 429634 Brake Caliper https://www.amazon.co.uk/dp/B00CPNSGLU/ref=cm_sw_r_cp_api_ZCJKxbZ7HX2SW
Fuel Parts REA1002 Alternator https://www.amazon.co.uk/dp/B00497T74K/ref=cm_sw_r_cp_api_MFJKxb3ZZE3VW
So it has :o
Received the Hella A/C compressor today, Also came with new seals. Well chuffed.
That's a great deal! :y
I had a peruse last night and spotted front shock absorbers for £7-8 each! :y Unfortunately both suppliers who had them at that price only had one and they were supplying different brands. ::)
Most of the bargain stuff has gone now . Where it states only 1 item left use the dropdown
to order 2 and sometimes it works . Had to clear another shed out for the new spares
:D
Is £11.53 good for a brake master cylinder? There's no reduced from price on that one
:D
I tried to order 2, but they wouldn't have it.... :(
Spent near on £60 on stuff I don't yet need, ironically the rocker cover gasket I do need would take 2 weeks so cancelled that!
Got a few other little things for the other Omega.
Triscan x2 vented front brake discs £11.81
NK x2 vented rear brake discs £6.25
Don't need these but may come in handy: ABS Tie Rod both sides £14
Noticed there was a pair of PFL new headlamps for sale at £10 each they seem to have sold now though can't find them. Depo was the brand in sure.
Not sure what these are for but does say for GM vehicles.
Laser 3581 Engine Timing Tools for GM https://www.amazon.co.uk/dp/B0036WZM6Q/ref=cm_sw_r_cp_api_xwtLxb6SWVNMT
Edit:
J.R. Tailor Fit Car Mat Set, Standard Navy with Orange Checkered Trim - Vauxhall Omega 1994-2003 https://www.amazon.co.uk/dp/B009Z7JQCC/ref=cm_sw_r_cp_api_zCtLxb2HZ0SH4
https://www.amazon.co.uk/dp/B00BNZEI4U/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=JW3RQ4FICN9J&coliid=I1MXIVSO578VER
looks to be the early 1994 headlamp going by the part number.
don't need one must resist :D
John.
Fits my 2.5 V6 according to amazon
