Omega Help Area => Omega Electrical and Audio Help => Topic started by: hoj on 22 July 2016, 15:10:53
Title: P C B s
Post by: hoj on 22 July 2016, 15:10:53
Are the dash PCBs the same on every model or different?
3.2 petrol compared to 2.2 DTi for instance
Title: Re: P C B s
Post by: Marks DTM Calib on 22 July 2016, 15:50:14
There are variations, obviously a 2.2dti will have a very different rpm gauge to.
Title: Re: P C B s
Post by: hoj on 22 July 2016, 19:31:16
Would the wiring (pcb) to that guage be different then
Title: Re: P C B s
Post by: Doctor Gollum on 22 July 2016, 21:45:02
Have you checked the fuses and tried reseating the cluster?
As per the guide... :-X
To put it another way, swapping all the cluster components won't fix it...
Title: Re: P C B s
Post by: hoj on 23 July 2016, 13:02:11
ALL fuses are fine as for the clocks I've had them out 3 or 4 times
I did notice a split in one corner of the original PCB so changed it with one I had but that was from a 3.2 petrol hence my original question
The clocks all lights up but no clocks actually work and no warning lights come on when ignition is switched on
Title: Re: P C B s
Post by: zirk on 23 July 2016, 13:09:21
Have a look for a burnt Resistor or burnt or blown track on the pcb film.
other than that its time to get the Voltmeter an start checking volts / earth from the connector.
