Omega Help Area => Omega General Help => Topic started by: gbh on 06 August 2016, 22:25:35
Just noticed today a little seepage of oil from 3 or 4 of the bolts do you think its the O rings that need changing? The breathers are all clear or maybe they need the torque checking although i think they may well be original as the car has only done 50000 and i can't see it mentioned in the service history!! Your thoughts and can you but O rings separately?
Yeah it will be o rings. But you need to remove covers to get to the o rings so. As it's such a ball ache of a job do the gaskets too :y
For a "temporary repair" you could torque them with the hope they've just come loose. But doubt it :y
I had two weeping so after a bit of advice i ran a bit of black sealant around the hole then dropped the bolt back in. No more weeping. Its been about 3 months so far :y
Or this :y :y :y
Check your breathers. IF they are clear they should suck air in, not blow oil out.
Also check that the cam cover bolts haven't worked loose (torque to 8nm).
